you mean if wanna install piston...
total should be around RM4xxx ??
yeaps, thts the amount u need as backup
there will be more expenses on the way when u open ur block
oil seals , metal gasket and etc
walao !!!!!!!!!!!!!
nvm forget it
2200 piston alone..4pcs piston and 4set piston rings and piston pin..
to install need to rebore rm200 plus..
then buy gasket,etc..etc labour around rm1k plus...
so ya 4k plus total damage...
yups..
then might as well change conrod together..we have pro H beam rods...for your car..RM1800...kekekek
then race series bearings...rm680...etc..etc...
KOYAK
yah can no probs...sound like 2 bar also can tahan kekeke
wow u must be crazy! hehehehi dapat cari BC cam, stroker kit, if lain kali i project, u dapat kirim all stuff and do it? maybe change to manual, and microtech.. lama lagi tu...
stroker no need la..orang sabah is gila ma.. lolzz
tapi lama lagi la.. BOT 1st.. see hows going...
because i saw BC got 272 turbo cam, valve spring/ retainer, valve, conrod, crackshaft also ada... stroker tu...
if project no body i will find but u :)
1st week july i back kl, i cari u discuss tu BOT ok? cheers bro
u change piston and gasket ok d la..
Similar threads | |
