4G9x New Original Turbokit with Garrett turbo
good stuff ,a pity i got no so much budget......
Hi, can this kit fit 4G93P Siemens version?? Pm me your best offer without installation.
fuhh...running on what boost???.....0.5 or 0.8 boost?..
bumppp wonderfull item:itsme:
Sadly my 4G92P is tuned with high compression pistons, a bit fear if I go and take ur kit~~
bro, pm me if u've kit for chevrolet aveo. thx ;)
can fit on 4G92 MIVEC DOHC??? no need to change piston or anything??? mivec piston really hight compression...
Hi Bro,
No need to change pistons, I will provide a 2 mm headgasket but it will work better if you run a lower temperature thermostat with a new fan controller. Lower temperature means u can run higher boost. Thanks.
Your BOT package looks really good.
Sound like a better option than opting for a transplant.
My current setup:
4g92p sohc
Upgraded intake runners from 4g93
Exhst manifold - mivec
Afc Neo
Drop in k&n
Afr
LCP
Current mileage 320km
Considering the above items, can my setup take the boosting?
What abt after sales service?
Thank you.
Just to put my 2 cents worth cos I've seen the kit and love it, but outta my budget sadly.
It's very low boost, meant for low lag and low level torque and hp increases. It's custom built FOR the 4G92 engine. Stock internals are fine as long as your engine itself is in good condition. The kit looks fabulous in real life, and if you cna afford it, I say it's a great upgrade with reliabiltiy and daily driving in mind.
Thanks Bro PeterFrancis, Yes its custom made for the 4G92 SOHC. You wont need the mivec extractors or AFC neo as it comes with its own piggyback.
Hi Bro..
my name is vincent
i bought w 202 c 180 a few months a go, with garrett t 25 and mosselman kit instaled, but looks like there are several modification, now my turbo have a probleme and have to repair, can you tell me item list in mosselman package inside, in your photo , it seems .. threre are a piggy back ( correct me if i'm wrong) , can you tell me more about it.. please PM to me at [email protected], thank in advanced..
Hi Bro..
my name is vincent
Hello Vincent, I have sent you and email on the details you have requested. Thanks
bro..pm me the price for bot kit for sgti 4g93 with siemens ecu..and how much power gain?
