fuel regulator
Gt i need to ask you something.
I felt my car FC was pretty good when i left it at around 29 at idle...but it did feel abit sluggish compared when i set it at 39 at idle.At 39,the car feels nice and smooth,easy to accelarate.but FC quite bad.
The question is....if i were to keep it at 29psi...is it possible that will cause my mixture to be lean?
Or will the ecu auto correct the fuel mix ratio ? If this is so,does that mean my FPR only serves the purpose of making sure the injectors spray are finer and wider?
1 way to find out whether ur runing lean or not bro.just take out ur plug n check it.
btw,what engine r u using?b16 ar?fpr will also increase the amount of fuel imjected
into the engine.r u using the correct heat range for ur plugs?
.if the plug is whitish? its lean ? heat range for my plugs should be correct i guess im using iridiums
that's mean ur using no.6?yup.whitish mean ur running lean.usually they set their fpr
for vtec is around 40-44 psi at idle.maybe ur fc sucks cos ur vtec always kick in kot.
Hi..
Since i'm changing to walbro fuel pump,reading at the regulator became not stable,needle show at 3 to 4 bar when engine idle..What actually happen?Should i re-set my AFR when switching to walbro fuel pump?What the ideal setting for my car lantis with B8 BPT.?:hmmmm:
TQ..:hmmmm:
Eh guys i have a question ... Will Fuel Pressure Regulator (any brand, like arospeed, sard) works on N16 Sentra QG16DE Engine ??
Hi..
fpr or afr?if fpr,yes.if afr,depend.if ur afr is stoich,there's no need for u tempered with it.
usually for bpt is around 45 psi.the truth is there's no ideal setting cos the setting depends
on what u did to ur engine.
Ok er .. Firstly thx for replying my numb question ... But i wanna ask , will it make at least 1 hp to the engine ??
maybe or maybe more depends on ur mod.
I did all the basic mods ad ... Which are I/H/E ... Lighten Pulley, Sparkplugs ... What is needed is done ... Hehe so how much i can expect to gain ? I assumed i am bout to gain 3hp for this regulator ...
got upgrade to oversized throttle body or not??...
Was thinking to install a Q45 Throttlebody along with the fuel regulator ... What throttle body will be suitable for Qg16 ?? And can i just install the FPR without having a bigger throttle body ??
thanks bro,
FC difference at this 2 settings actually not much laa...i was just being paranoid.Drasticly reducing the FPR only cause lack of power and not much improvement on Fc.
ill leave it at 40psi...and run it for few weeks see how the fc..maybe that time i just install testng the car too much then FC naik severely....hehehe...i love the power and the way it accelerates when its at this setting...so i thnk im just gonna leave it at this...heheheh
some us forums were saying that the fpr is pointless cause the ecu auto adjust the fuel ratio...and it doesnt serve "much" purpose....so when i reduced it drasticly to 29 it was just a test.. at times i dont trust my own buttdyno...thats why i wanted to get opinions...moral of the story is...(for me) FPR good !
Bros,
Why does my engine bay have petrol smell...and the smell is coming around the fuel regulator area...do i have a leak?
Bros,
u need to check thoroughly bro.i don't want to see ur car end up in tv3 news like
the gen2 that burst into flame a few days ago.check ur fpr n fuel line from the
fuel tank to the regulator.
Weeeeiiiiiiii Dont la Scare Me Like That @!@!@!@!@!@!
hmmm i just did a brief check..and put my nose close to the area where the smell is coming from..it seems its not from the fpr line it self..i dont see any physical leaks or any marks of a leak...how else can i determine if theres a leak?
Its definitly around the fpr area and fuel rail area. but i cant see anything.What do you suggest i should do bro?
u should use high press hose from fuel rail to fpr
Bump: u should use high press hose from fuel rail to fpr
Hmmm...is that the only possibility? i might just try that and see..Thanks EGNINE bro
i set my sard fpr on my b8 180 at 40psi during idle. but then ho...after drive the car, the fuel pressure was drop to 20psi :banghead:
after the engine is cool and i start again, it will go back to 40psi again :(
i try 2 fuel pump from KFZE and SR20, both giving same problem. how come?
should i pull direct power from battery? i change my fuel filter but still same.
today i checked my engine bay again,i noticed that there is some oil sediments left on the FPR..its most obvious or darker at the FPR line where the fuel line connects to the FPR...im thinking this is the culprit and i think it only leaks when im driving at full throttle...
I wiped off the oil with my fingers and smelled it..it had the scent of petrol on it.I wiped the area clean...and while my engine is idling i pulled the throttle,i didnt see any leaks or anything being purged out by any of the lines...im assuming it happens when im at full throttle...
anyway,what ill do is...ill check tomorrow and the day after just to confirm if theres oil leak from the hose connecting to the FPr..if there is ill have to change to a higher pressure hose like EGNINE mentioned...Any particular hose that i should look for? Can i sue those silicone hoses? is it safe?Thanks Bro's.
New Posts
