Microtech
Teh Microtech LT10-s have Gnd at beside the crank input 1 and also the Power M/C beside the crank input 2 is use for what? Where I can get the ignition input drawing diagram?
Bump: Teh Microtech LT10-s have Gnd at beside the crank input 1 and also the Power M/C beside the crank input 2 is use for what? Where I can get the ignition input drawing diagram?
hope this will help u out..its lt8 but the crank sensor wiring is 100% the same..
http://www.microtechefi.com/pdf/LT8HONDAVTEC16Toothanti-clock.pdf
Bump:
try this la..
the lt10s and lt8 shares the same cranksensor wiring
:confused: best,good,performance for microtch,that wht i know.... i want try 4 my wira mivec but stil afraid about wht happen 2 my friend, 1 week after instll, engine get overhl, piston ring jam, oil engine smell petrol, full tank petrol can use about 200km..... explain bro.tq:confused::confused:?
Bump: :confused: best,good,performance for microtch,that wht i know.... i want try 4 my wira mivec but stil afraid about wht happen 2 my friend, 1 week after instll, engine get overhl, piston ring jam, oil engine smell petrol, full tank petrol can use about 200km..... explain bro.tq:confused::confused:?
y your friend so poor thing one..
could be due to many factors...poor rebore or timing not right or fuel pump presure not constannt..
since u scared better u install afc la..:biggrin:
U cant say the ECU is a problem,over 100pc of ecu im install with stock engine,never facing any problem.But some time have a problem with the other engine rebuilder.For me when tuning for daily driving we make a economic fuel comsuption.For boost and performance depent on your engine set up.For stock Mivec 1.6 we make 165whp and good torque.Pls beware with a Non Authority Microtech tuner.
Bump: U cant say the ECU is a problem,over 100pc of ecu im install with stock engine,never facing any problem.But some time have a problem with the other engine rebuilder.For me when tuning for daily driving we make a economic fuel comsuption.For boost and performance depent on your engine set up.For stock Mivec 1.6 we make 165whp and good torque.Pls beware with a Non Authority Microtech tuner.
:driver: thanks bro!!! maybe
(Pls beware with a Non Authority Microtech tuner.) my prend say, 'tuner' at industrial area in subang... jz beware maybe....:wavey:
Bump: :driver: thanks bro!!! maybe
Yah good for u and your frends..:biggrin::biggrin::biggrin:
Better go to Mellinium la bro...he expert person about mikotek la bro.Have a good dyno facility there.:rofl::rofl::rofl:
Bump: Better go to Mellinium la bro...he expert person about mikotek la bro.Have a good dyno facility there.:rofl::rofl::rofl:
How I can change the Input Trig and Out Put Trig? I cann't find in the Microtech LT10 inside the setup screen!!!! My only can see Teeth CAS and TDCref CAS. How I know the microtech ECU for the car model? Thank
How much would you usually be able to tune for a 1.8 mivec with stock cams and stock CR of 11? Using 1.8 stock pistons. Thanks
Bump:
That ECU for Nissan engine.
Bump: Around 170-175whp but Mivec come from Mellinium all power2.Like a KAP from MAG.Izam Mivec and others.
Bump:
That number the Hp is NA la bro not for turbo la.Kalau turbo charge already 320whp and 300lb torque.
Yes but most are turbocharged! i plan on keeping mine NA...thanks for the info!
Bump: That number the Hp is NA la bro not for turbo la.Kalau turbo charge already 320whp and 300lb torque.
A class.
1.charade 4wheel.
2.Evo9 stpowered.
3.Evo7 th 87
B class.
1.Ah lai r eng.
2.Blue satria(otr body)
3.:confused:
C class and others
dint pay attn....:sleep:
very late race edi...but good new timing light and damm big screen timing result,juz
the placement a bit off..could be higher would be nice...:rofl:
A class.
1.charade 4wheel (10.9)
2.Evo9 TH87 (11.5)
3.Evo9 STPower (10.3)
:driver:
Bump: A class.
2.Evo9 TH87 (11.5)
:driver:
