Microtech
Hi all the microtech experts,
I am driving a Suzuki swift Sport ZC31S Engine Model M16A.
I had purchase a second hand LT-10s from someone which was driving a Suzuki swift sport zc31s as well. The different between my setup and his was he is running on turbo and I am on NA. I would like to install the LT-10s into my car.
I got a few quires hopefully somebody are able to help to answer.
1. Since the last owner actually used the lt-10s on a turbo setup, does the lt-10s require sending back to Australia for reconfigure?
2. As Suzuki swift sport is using E-throttle rather than the traditional throttle which drive by cable, will the LT-10S be able to support this setup?
3. According to some tuner over in Singapore, they had mention to me I have to install an aftermarket crank pulley with additional cam sensor for the lt-10s to recognize the cam signal input. Is this truth?
4. Will there be any additional sensor or items I require to purchase in order to get the lt-10s to be installed in my car?
Hopefully all the experts are able to help to clear up my quires.
can wire antilag like those inbetween shift one? not launch control.
http://www.youtube.com/watch?v=mXfUbFR-x7g
Bump: Hi all the microtech experts,
No need, you'll just need to use the vacuum load maps.
Microtech cannot control E-throttle, either change it, run it along side with the stock ecu.
Depends on whether the microtech was made for your car or not. need to check with last owner if he had installed an extra sensor or wired to stock crank angle sensor.
Depends, if the microtech can read your CAS, Water Temp, everything should be pretty much ok..
Brother the Microtech LT10 use in Honda DC5 K20A3 engine then now want use it to install to H22a or not? How much u charge for installation? Thank.
Bump: Brother the Microtech LT10 use in Honda DC5 K20A3 engine then now want use it to install to H22a or not? How much u charge for installation? Thank.
instalation and fuse and relays RM600 including aircond wiring...
and dyno tuning rm600
so total rm1200
Brother than mean Microtech LT10 use in Honda DC5 K20A3 engine then now want use it to install to H22a is no problem?
Bump: Brother than mean Microtech LT10 use in Honda DC5 K20A3 engine then now want use it to install to H22a is no problem?
the trigger tooth is the same on the microtech on both the motors..
just few minor setup to be reconfigured..thats all..
Bro what is the most suitable model for my B16a track car race engine? (For 1000KM or MSS race)
Best price and please PM to me....
Thanks
Thanks
we can do u special price on the LT10s plus install and dyno tune and maybe touch up on the road as well...for a special race price at RM4500...nett...no more hidden cost..
promo price...
:driver:usually retail is rm4800
Thanks for the explaining.
i got a couple of question in mind.
1. Will the idle rpm able to adjust if run side by side with the e-throttle?
2. The crank angle sensor he did install an extra sensor, therfore i am not sure will LT10s able to read my stock crank angel sensor or not. according to my understanding the stock crank angle sensor is require to control the VVT.
3. There are no other additinal sensor he install as he mention what ever is require to be install he had pass me as a whole set.
Bump:
so total rm1200
does the price appliable to install and tune on suzuki swift sport ZC31S?
How long would it roughly took to install and tune if it is possible to install.
Bump:
sorry never installed on a swift before..
Bump:
Bump:
sorry never done swift before la
will there be any chances to install?
no idea..but if u buy new unit from us we can order the rite unit for your car and we can install it for u..
but to modify diff car into it we dont dare try and r&d..
sorry
Brother don't be angry with my question because I don't know anything about it, my frineds told me the LT10 use in Honda K20A3 cann't use in Honda H22a. Have u done it before? He told me the Honda B series same with H series and no sure can use in K series. Thank and sorry to disturb.
Bump: Brother don't be angry with my question because I don't know anything about it, my frineds told me the LT10 use in Honda K20A3 cann't use in Honda H22a. Have u done it before? He told me the Honda B series same with H series and no sure can use in K series. Thank and sorry to disturb.
buy new one la..
:biggrin:
Who have mircotech LT10-s wiring diagram use in Honda H22a!!!
Bump: Who have mircotech LT10-s wiring diagram use in Honda H22a!!!
check the web microtecefi.com for wiring diagram.if u have more credit call Jon for ask a question.
Bump: check the web microtecefi.com for wiring diagram.if u have more credit call Jon for ask a question.
h22a and b16a and b18c all same wiring..if ek b16b only obd2 different wiring..
Bump: h22a and b16a and b18c all same wiring..if ek b16b only obd2 different wiring..
Teh Microtech LT10-s have Gnd at beside the crank input 1 and also the Power M/C beside the crank input 2 is use for what? Where I can get the ignition input drawing diagram?
Bump: Teh Microtech LT10-s have Gnd at beside the crank input 1 and also the Power M/C beside the crank input 2 is use for what? Where I can get the ignition input drawing diagram?
