Iswara quickshift
diwant
187
2
3,018
Bangsar
diwant.wordpress.com
i just installed quickshift gear lever into my iswara, and i think the pros are:
1. shorter shift length
2. firm shifting
3. no big clearance between gears
cons:
1. use more energy to shift
2. shifting from 2nd to 3rd gear and 4th to 5th gear a bit difficult since we have to find the correct line before shifting. (compared to standard gear lever where when u free up the gear it will automatically centered itself)
what u guys think?
frank118
435
24
Never tried a quick shift...from lane to lane yes?...Any good or cons on this sifus?
shah5755
355
31
Pj....kch
i've used it more than a year plus oredi...so far no problem hehe only after installed a bit difficult to shift but after few months ok oredi maaaa.....you juz need some practise,practise makes perfect:burnout: so far no problem....................:driver:
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Hahaha, won't spoil your gearbox ler. Keep on practicing, don't give up. It is just like having a racing clutch and a strong spring cover. Initially, you say "Not syiok at all, so damn hard, jerk here and there". Once you get the hang of it, you ejaculate on the spot...
frank118
435
24
HAha...must be fun...have to try and see...just afraid I wont get used to it and get all the wrong gears...have to hang a large "L" on the windscreen...
But they are quite affordable...seen some cars with it without cover looks bad though. Is it normal that after putting in the the quick shift u cant cover back?
lcchong
84
13
1,508
ejaculate on the spot... :rofl::rofl:
frank118
435
24
After installing can normal gear knobs be used. Saw some with a ball on top, doesnt look comfortable le...
Comments?
JackWaiKit
262
5
www.friendster.com
it's actually just a momment for u feel exciting during gear changing...
Close ratio GB feel better than short shifter!!!
It's just a matter of your passion!
joev8796
145
if u hav a close ratio GB 2gether wit short throw shifter, da fun is double up.
but close ratio GB onli contribute in better acceleration n sucks in high speed rite? coz da rpm is damn high in high speed crusing but anyway, can ply wit fun if havin a close ration box
Bump:
My wira converted to 4g93 with 4g94 crankshaft.open mod.
The engine still berpantang.usually drove under 3.5k rpm.when i try pedal to the metal (under 4k rpm) it will jerk.when i drove it normal till 4k rpm, no jerk.
I still havent install management yet.wait till habis pantang.
Anyone can explain to me.is it coz of needed management or sumtin else?
Thanks guys
