- Joined
- Oct 20, 2008
- Messages
- 263
- Points
- 1,518
well..im a L5 user
specifically in L5 singlecam sohc 3 silinder
what can i say is if pikap from 0 - 100kmh
defenitely kancil turbo will win with stock turbo engine
in long distance....of couse la bigger cc car wins
L2/L5 cut off at 140 kmh
if it been removed,then 180 kmh should be no problem..but the enjin will shake lar because of 3 silinder enjin..plus 660 cc only..hehehe
if L5 16v twincam 4 piston turbo..
it can reach till 200 kmh with speedcut had been removed
the engine will running smooth because of 4 cylinder dohc
believe me or not...140 kmh feel like driving a wira at 100 kmh
hope can share info here
Bump: here is the daihatsu mira engine spec
only post to share the info
Daihatsu Mira (aka Perodua Kancil)
L55,55v,56v(AB) - 547cc 4v 29ps/6Krpm 4kg-m/3.5Krpm turbo/NA
L70s,70v(EB) - 547cc 6v sohc 34ps/6Krpm 4.5kg-m/3.5Krpm turbo
L71v(EB) - 547cc 6v sohc 52ps/6.5Krpm 7.1kg-m/4Krpm 4WD turbo/NA
L200(EF-CL) - 659cc 6v sohc 40ps/6.5Krpm 5.3kg-m/3.5Krpm NA
L210s,210v(EF-HL) - 659cc 12v sohc 50ps/7.5Krpm 5.3kg-m/4.5Krpm 4WD turbo
L200(EF-XL) - 659cc 6v sohc 61ps/7Krpm 8.6kg-m/4.5Krpm turbo
L200(EF-KL) - 659cc 6v sohc 42ps/6Krpm 5.4kg-m/4Krpm NA
L200(EF-FL) - 659cc 6v sohc 40ps/6.3Krpm 5.3kg-m/3.5Krpm NA
L200,200s(EF-JL) - 659cc 12v sohc 64ps/7.5Krpm 9.4kg-m/4Krpm turbo
L500s(EF-CL) - 659cc 6v sohc 40ps/6.5Krpm 5.3kg-m/3.5Krpm NA
L500s(EF-KL) - 659cc 6v sohc 42ps/6Krpm 5.4kg-m/4Krpm NA
L500s(EF-FL) - 659cc 6v sohc 40ps/6.3Krpm 5.3kg-m/3.5Krpm NA
L500s(EF-JL) - 659cc 12v sohc 64ps/7.5Krpm 9.4kg-m/4Krpm turbo
L500s(EF-GL) - 659cc 12v dohc 52ps/7.2Krpm 5.8kg-m/4Krpm NA
L510s/510v(EF-ZL) - 659cc 12v dohc 55ps/7.5Krpm 6.2kg-m/4Krpm 4WD NA
L500s(EF-RL) - 659cc 12v dohc 64ps/6.8Krpm 10.7kg-m/4Krpm turbo
L502s(JB-EL) - 659cc 16v dohc 58ps/7.6Krpm 5.8kg-m/5.6Krpm turbo
L502s(JB-JL) - 659cc 16v dohc 64ps/7.5Krpm 10.2kg-m/4Krpm turbo
L512s(JB-JL) - 659cc 16v dohc 64ps/7.5Krpm 10.2kg-m/4Krpm 4WD turbo
