GAB adjustable prob
flat_tyre
hi guys, sorry if i put this in the wrong section.
i bought my GAB HA adjustable a few weeks back for my satria. but sometimes when i run into a bump or an uneven road, there's a weird "kTOKKK" sound coming from the rear right absorber. anyone experience it? whay does this happen yea?
I've used the same type of adjustable like u
for 3 months now but still no problem..
Maybe u should ask for replacement as
it should be still under warranty....
i also used same type wif yours for my wira and now almost a year and half. also experience the same situation in the beginning but at front left. send back to the distrubutor and found my lower arm already worn out. after change new one for front and rear also left and right, the problem gone already. i'm using it to ride high. how about u????:wavey:
I may suspect ur coilover height isn't same for the particular asb...
Try to check it!!!
But after adj need to align back the toe & chamber!!!
Good luck!!!
so sorry guys...
this maybe a bit out of topics...
I use to adj my D2 myself...
When the coilover height not level/same, the spring sound come out...'kteeeeeeeng'
After adj...seems lesser!!!
where did u sent ur car hafiz? to the GAB distributor or ur mech?
i've sent it back to sole distributor to rectify the problem. when the problem know then they suggest to combined with eg std spring. and now my asb preform well and more comfortable....
i bought this asb at boost zone jb, the only sole distributor for rs one in jb
