Hello all sifu out there need your guys advice and help.....now i am going to swap in 20v blacktop into my corolla AE111, but i prefer used back the original meter due to the levin meter not fit to my dashboard. Any problem with the original 8000rpm meter for the 20v blacktop? will effect the engine performance or not? Or must used back the levin meter only? Any sifu done the modification on the meter pls give more advice, 9000rpm thanks to you guys he he he......
Update:
Below are AE111 auto meter pin out and Levin manual meter pin out. who once to used back thier stock meter for blacktop conversion may refer here. he he......
Update:
the speed cut is control by ECU right? The stock Speedo is drive by cable and the other 2 pin out wire is go to ECU izzit? its that both wire is for ECU reading the speed and perform speed cut??? :hmmmm:your guys input are much appreciate
