Specialist in S15 specR(workshop around subang jaya or puchong etc..)
maddokun
Hi guys,im new here...i would like to ask u guys where should i go if i have problem with my S15..the problem is all my sensor light on dashboard not appear before starting engine(sometimes happen sometimes OK)..this problem start after i got problem with my ignition coil..after checked,one of my ignition coil detected not working...so i changed one of my ignition coil and the problem at engine side seems OK(no jirking anymore):biggrin:,but the censor problem still on and off+my car always "mati" when i step on gear 1 to move:mad:..usually when traffic jam or slow moving(air flow not consistent base on engine sounds)..i went to ae workshop and checked the computer condition there are two error code appeared: 1)mass air flow sensor 2)IGN signal primary..as u know ae most formerly known for its subaru specialist so here is there any recommended workshop around subang jaya or puchong for S15(reasonable labour rate):banghead:?...other than links dyno tune please....peace~~~:biggrin:
TRY others with dyno in sunway!!!:biggrin:
Bump: the price is ok ok...la! on fixing problem..
do u know any workshop for S15 hanslin?
:wavey:i'm neutral my friend, i just can said.......
some are good in tune
some good in building/rebuilding
some have in stock
dont worry fixing problem is not exp....:nurse:
Bump: :listen:fixing is to with std n upgrade is diff....:cheers:
hey thanks for the info...already found Onward....:biggrin:...btw where is under5 ha?
In Tmn Perindustrial USJ1. Near MyDin/Summit USJ. Check your PM for contact details. Cheers
Rerider, is Onward near the new Giant at Puchong Kinrara Jaya????? I past by the other day they got quite a number of Silvia's and Skylines..
I send my s15 to puchong perdana. A very knowledgeable but low profile technician who does alot of silvia's. If you're interested I can direct you there.
Wiring/earthing on loose probably.Just take a minute to look around ur ignition and AFM sensor.
Write your reply...
