overseas are usually mix-n-match of 2-3 turbos to make one...if you'd like one, we can....
topic starts on Holset...ends up with a dare on GT42R ? questions are ambigious and leads to nowhere guys...come on...back on track.
As for your earlier question..are you asking if someone is gonna sponsor a 42R vs a S374 or something ?
sponsor is a nice word..and easy to use mate...
i got turbo one sticker on my car... sdf sponsored me... sponsored me 1 teh tarik.. so i put sticker...
just sold my gt35r to my friend...will switch to holset in order to archieve traction as i'm using fwd...the boost from gt35r kick in too aggresive and not linear...
bro u should try to change the turbine first for fwd car..there is 3 combination of turbine ar for gt35r..u should use the bigger when high boosting..
i have a holset turbo HIE,HIC,HX35,HX35W,HX50,H2D,HY50, WHICH ONE U WANT TO COMBINE :d hehe..PM ME
well well...
to correct some facts :
1. GT Ball Bearings are now repairable. Genuine Garrett ball bearing cartridge ex-stock and ready to ship. Don't let old info block your vision, Call our dealers for more info.
2. Holset has many wheel trims and sizes as well. HX 35 to HX 40 there are easily 5-8 wheel sizes. :hmmmm:
3. HX series has many turbine housing sizes as well...so do some homework before getting one. :hmmmm:
4. Garrett GT series run over 2.5bar with ease and requires less oil and has less heat soak back. Ron Lumus (Garrett sponsored) in his Drag cars run up to 60psi with GT4718R's...no reliability issues.
5. Brent Rau swaps a turbo after every event. (reliability ?) and his configuration is RWD tube frame revving to 13k RPM and the Borg Warner doesn't even build boost till past 7k RPM.
6. Yup repair kits are cheap for Borg Warner and Holset, but fact is also, if "thrust play" comes into the turbo, it's a goner as well...no difference from any other brand of turbo.![]()
7. Garrett GTBB turbos don encounter "thrust play" hence the only time it fails is due to :
- engine failure, leading to no oil supply
- extreme heat soak back (water lines must be run)
- foreign object / particles impacting the wheels (turbine or compressor)
or else....it'll last a hell longer than most journal bearing turbos.
Anyway it's good for others to opt for something exotic or weird or new to try. My point is, to ensure a healthy motorsport community and to correct facts as far as we can. Myths don't carry weight...Facts do..![]()
