apa lagi bro, raya over liao.... its time for your project to kick off liao
so..is it safe??
aiyooo..still confused haa hahahahaa...cum..cum..let us all guide u hehehehe
rite now i don't have anything on the floor..just that 4g67 on my engine bay..
i'm planning to put 2jz pistons..about money,not much laa..so i have to be money wise..
hehhehe
Pm or call me if intend to look for turbo parts...
want to clear my house...all are vr4/evo parts leftover...hehehe
p/s - cannot list down item in here....this is not pasar malam ar...ekeke
i'll pm u...![]()
since that u r already using 4G67 engine, i think not much item need to find anymore..
Because u can used back 4G67 item. But if u can find a vr4 part. It better 4 u.
here is 4g67 block after rebore to 85mm.. As u can see, the wall is still thick.
http://i287.photobucket.com/albums/ll155/eci4ever/Kereta/g67.jpg
haaa wut r u waiting for mann..head use back 4g67 head to rise the comp a bit.Advantage of early spool up. for the piston make up ur mind which piston u want to use. coz this is a 1 time job only to bore the block...it's a complicated thing to do if u change ur mind want to use bigger diameter piston in future..so might as well do it 1 time only. My suggestion is go get urself a forged piston la bro 1 time investment only. then no need to worry can boost 2 bar or cannot or wutsoever la.Think about this wisely. hehehe racun..racun hahahhaa
Waaa.. u can recognize e3 piston.. Sure otai ni...4g67 block with evo3 piston...sure lazat haa...huhuhu![]()
This topic is to share how to bring out a team and type of engine preparation is needed! N if things goes well it might became true that a team 0-100 member will step up!! I should start with race type...
