Best tuner
woooyoooo...Jink,u have to look the good stuff he set up the engine.many2 custom lol...if TDO5 can go 9sc..GT turbo cannot laku laa...hehehhe
4g63 ppl should check out joebucci's setup
his td05 14b setup gave him 10.8 seconds
now with 16g + nitrous he is in the 9sec
huhuhuhu
http://joebucci.com/index.htm
If u are running 98octane fuel u cant get that number HP.Q16 better than C16 fuel.Q16 have a oxigen nated.price xpancive.Mellinium motorsport have 4 drum stock.From the high octane number u can up the timing deg and can see the high HP and torque with low boost.
If S258-450hp bolt on GSR 1.8L with stock engine,confirm u can get the power 300whp at 15psi with microtech and 750cc injectors.your car is power full stock engine.
bullseye bai :D , td05 flange turbo , got HX35- 550hp , HX40 -600hp , S258 - 450hp , S366 - errr too high, forgot hehehe
If u running with E85 Etahnol...u can see huge number of torque.I have stock of E85 for running coolder inlet Temp..but crazy respond when u run with nitro methane fuel.Last time i smile alai jb car have a Methanol at sepang.. hahaha
hehe , make laaaaaa own E85 :D
Sure bro..no worries.I order from Australia..very hard to find here..and still waiting Nitro Methane..just for testing.hehehe
hehe, if u manage to make it let me know, also want to research bout it, but where to find ethanol :P
E85 can mix with petrol..and u can get around 113 octane number.For NA engine can up to 40deg timing at 9000 rpm.
Nitromethane is very xpensive and dangerous to handle. The interesting alternative to patrol is Methanol. Methanol will make more power, typically around 20% more power than a similar engine running patrol. Some things to consider in running methanol is your fuel system will have to be completely changed and upgraded.The fuel system will have to flow approximately 2.5 times as much as the patrol engine.
Old timer saying is true. "Gasoline is for washing parts, alcohol is for drinking and nitro is for racing champions."
E85 actually means 85% Ethanol , 15% Petrol
Ethanol can buy from malaysia bro , i got the list of suppliers , but must buy in barrells la :)
I think u can only use for ownself, cant mix can sell :P malaysian law
