Recommended tyre pressure
DLegend
Official Contributor
430
14
5,018
jayjaynyc.blogspot.com
My front is 33.5 psi front and 31.5 rear - Potenza RE001
Front is 32.5 front and 30 rear - Falken FK452
Try different pressures for different tyres, some will need more to feel good, some need less... :driver:
egb18c
922
94
kuantan
250 kpa at d front,n 220 kpa at d back.
fuel saving tip.not handling tip.
btr for d real should b less than d front tires.if u r using FF car(weight distribution)
if u wanna make ur car tail happy,then put d back tires to d max pressure it can takes.
triplor
366
4
mine advan neova 195/55/R15 front&rear 215kpa @ 31psi..
saw one schedule table on air pump at shell indicate recommended pressure based
on how much ur C.C vehicles....
renxun
1,138
37
1,648
32psi for the front and 41 for the rear. - my drift car..
29psi for the front and 41 for the rear - dmax 2.5 according to the sticker at my door
realplayer
330
does anybody have the schedule table of tyre pressure??....mind to share here....:listen::love:
momosyah
82
The correct pressure has been established jointly between the vehcile and the tyre manufacturer. Your vehicle manufacturer may place a sticker adivising you of the correct pressures, on the door jamb, the fuel filler cap, in the manual, glove box etc.
nnik
3,676
Lembah Klang
wanna ask the expert here....how much psi need to use for 15" wif 50 series...which is best??? i used 30psi for front and rear...any pro n cons??????:driver:
ylkien
499
3,018
KL/PJ
Based on my exp, a lower profile tyre will need higher pressure. Also must take into account a heavier engine (if you have transplanted).
Mine : 205/45/16
Front : 240kpa
Rear : 220kpa
ylkien
499
3,018
KL/PJ
so high pressure pump in will not bumpy? since the profile so low..
Yea, a bit... But have to, cause anything less, and my thread wear isn't even.
Now, starting to save money to buy tires! They are expensive ^^
turbology
28
Your exp need to be update.
Tire pressure and tire profiles are not relative.
Most tires should run between 29-32psi.
And you have to take few factors into considerations for tires pressure:
1. Tires compound. Soft or Hard
2. Your driving style
3. Road condition
4. Comfort or performance
5. Load & weight. Any passengers or heavy luggage?
I run mine at 37psi front & rear.
I drive alone most of time. No lugguge.
I drive hard and corner hard.
My car have stiff suspension, so bumpy ride dont' bother me.
I have near 50/50 weight distribution. So all 4 tires are same pressure.
My tires is 225/45/17 with softer compound.
I "chalk" my tires. It says I am right. :biggrin:
Cheers
The Marketplace Top Posts
How envious are you at these 4 lucky Malaysians who won an all expense paid trip by Shell Helix to Abu Dhabi for their Fastest 48 hrs of their lives?? They'd be among the 200 guests from over 20 countries who will be visiting the one and only, famous Ferrari World Abu Dhabi, an intense ride in the world's fastest roller coaster in the form of a Ferrari, dubbed the Formull...
