l00kar0und
- Joined
- Jun 8, 2008
- Messages
- 3
- Points
- 1,501
NanoBlok
New improved:
- Better adhesives to hold the NanoBlok pad on the dashboard.
- Higher grade material and thickness.
- Improved Nano formulation.
Get further discounts for buying more than 1 piece!
1 piece: RM39.90
2 piece: RM70.00 - save RM10
3 piece: RM100.00 - save RM20
*Hurry! Promotion ends on 31st July 2008.
NanoBlok is an odor and bacteria killer, perfect for your cabin space in your vehicle. NanoBlok pad physically traps and decomposes bacteria and bad odor. It does not contain masking scents. NanoBlok is comparable to 1kg of charcoal in effectiveness. NanoBlok makes your car feel fresh!
Simply attach the self-adhering NanoBlok pad onto a surface where sunlight can reach. The dashboard or rear board of your vehicle would be ideal to absorb bad odours.
It is maintenance free and has a minimum lifespan of 2 years. It is sunlight (photo catalytic) activated with no mechanical or electrical parts. Works better than conventional ionizers and does not need parts extra cost to replace parts when faulty.
SIRIM tested, same technology used by Toshiba & LG. NanoBlok helps to get rid of the common smells that can be irritating to car users.
Examples:
- Dampened / wet carpet smell.
- Cigarette smell. (works best for drivers who smoke in the car and their passengers complain of the bad smoke smell).
- Sweat smell. (works best for those who plays sports often and doesn’t want passengers to faint from smelling your odour).
- Groceries smell. (works best for those who goes to morning market and doesn’t want fishy or meaty smell to stink your car).
- Musky smells from your air conditioning.
- Durian smell.
- Pet smell.
- Animal poop. (to those unfortunate enough to step on dog/cat poop).
- Vomit smell. (to those with babies in the car).
- Fermented milk.
- Food smell.
- Exhaust smell. (works great for diesel cars).
- New rubber mat and car plastic smell.
Removes toxin (gases emitted from vinyl or plastic materials) from brand new cars whereby this toxin can last up to 3 years. Toxic gases like benzene are the most deadly gases which can lead to eye irritation, lower respiratory effects and worse it can lead to cancer under long term exposure.
On an average survey, Malaysians spend at least 3-4 hours a day in cars. But if you like having car perfume then you do not need to stick NanoBlok on the dashboard. You can use the NanoBlok when your car stinks only in order to maintain your perfume smell.
Dimension: 12cm x 25cm x 0.1cm.
Coverage area: A single pad of NanoBlok works well for most standard vehicles. Placing NanoBlok on the front and rear parcel board for larger vehicles would be an added advantage.
--- Saves your money on car perfumes ---
An average perfume refill lasts about a month, over a period of 2 years is 24 months, which means you spend approx. RM240 every 2 years (for RM 10 car perfume). NanoBlok lasts for a MINIMUM of 24 months, which means you only spend RM39.90 instead of RM240.00. Car perfumes does not get rid of bad odour, it merely just hides it!
Delivery:
Free postage.
COD at Cheras area. Other location subject to availability.
There are many satisfied customers. Get yours now!
Call or sms…
Justin 016 6332299
New improved:
1 piece: RM39.90
Examples:
- Durian smell.
- Pet smell.
- Fermented milk.
- Food smell.
Delivery:
Free postage.
Call or sms…
Justin 016 6332299
cheers
