How To Increase Speed
EDRA
anybody knows how to increase speed without transplant engine? engine 1.3 only. i want 1.3 engine cecah 180km/j macam mana mau bikin?
easy...
1. port polish ur engine head and aftermarket camshaft
2. change to adjustable cam pulley
3. bigger intake manifold and throttle body
3. aftermarket air filter
4. port your engine block
5. aftermarket extractor
6. bigger exhaust pipe
7. aftermarket exhaust muffler
8. change ur plug cable and ignition coil
9. rechip ECU or put a piggy back unit or stand alone unit
10.make ur car more lightweight
11. and a lot more things to do...
my housemate car can reach 180 but his injection la. but if u can reach also no point because u only can stand if only for 5mins later temp will go up and need to slow down. if u really want to reach 180 try to change lower FD gearbox.
if ur car temp overheats after awhile of high speed run means something wrong with ur tuning and cooling system lor....
if still happens, try use higher heat range sparkplug... heat range 6...
i dont think traveling at 180kmph can cause heat temp go up, the radiator would be really cold down with that kinda speed... unless something wrong with ur water pump or head gasket...or either or coolant reservoir bocor, because when the coolant pressure goes over 0.9 bar the valve pressure realease to the reservoir and when everything ok it sucks back in...
bro i got one suggestion from one website from usa said that plug gap also effect to engine performance. if there are more fire that mean more power. what zth memmbers think?
performance plugs and cables wont make noticeable diff with a relatively stock engine, unless ur stock plugs and cables are already worn out
yeap try look for a weber dcnf...tuned properly ull have a more fun car to drive, driven properly, ull have negligible diff in fc
Is that all you want to achieve for your car ? Go faster ?
What about some decent handling mods and some better brakes ?
Haaaa....... bonus question for Sifu SkYwAlKeR........... :biggrin:
Yeah.. Safety First... :tee:
With good braking system u can PumP up out meter to 200km/h max speed meter for 1.3 Wira.... Huhuhuu
:rofl:
the most important b4 u want to make ur engine go faster is goto bank check ur saving account balance. after that goto powerzone and leave ur car there for 1-2weeks. then u will have a powerful car.
or else use vpower fuel saja.
