Nation Wide Authorized Dealers of Mythelogy Dampened Lightened Crank Pulley
GET YOUR MYTHELOGY DAMPENED LCP FROM YOUR NEAREST AUTHORIZED DEALER
Mythelogy Lightened Dampened Crank Pulley
Mythelogy pulleys are either made to the exact diameter of the factory-fitted pulley, or mildly undersized by not more than 5% in diameter. Lightening reduces rotation mass and moment of inertia for easier acceleration. Undersizing changes the ratio between the crank and the accessory pulleys, reducing the load on the engine exerted by the accessories.
To achieve perfect rotation balancing and weight-reduction, all the pulleys are machined out from billet AA6061 T6 aluminum alloy, which offers near perfect density homogeniality.
Mythelogy pulleys are embedded with a high-impact elastomer damper to absorb the vibration caused by the rotaion of the pulley and the movement of the crankshaft. Many user of undampened crank pulleys experience noisier engine, accelerated wear-rate on the bearing, oil seal , etc. Depending on the design of the engine, some models have stainless-steel crown for durability.
http://images.fotopic.net/ytoovf.jpg
http://images.fotopic.net/y0a4ku.jpg
For more information, kindly visit http://www.mythelogy.com
CAMPRO MODELS Please contact me at 019-3593909
