1/24 scale model 'kedai potong'
equin0x
Hi,
Anyone with any wrecked project or unwanted/unused piece of parts wanna throw up to find buyers? Anyone wanna find some parts to custom fit/ upgrade your model? Let's dedicate this thread to everyone to post up 'wanted to find' and 'wanted to sell' stuff/parts from the scale model.
I'll start off with I need to find any 15" sports wheel (preferably Aoshima but other makes acceptable) + tyre and a intercooler (in 1:24 scale of course!). Anyone with those stuff unwanted, pls give me an offer.
I've got a extra R34 V-Spec II front and back bumper, if there is anyone looking for it can throw me an offer too
ARTA, i see u got lots of wheel there.. anyone up for sale? hee hee.. and also the N1 exhaust?
anyone want kits, rims, pe (photo eteched) pls pm me..
already stock
AOSHIMA S PARTS TIRE and WHEEL SET No. 116
VOLK CE28N 19"
http://www.aoshima-bk.co.jp/whatnew/gazou120/03296.jpg
AOSHIMA S PARTS TIRE and WHEEL SET No. 120
SPOCON PARTS SET
http://www.aoshima-bk.co.jp/whatnew/gazou120/03432.jpg
ayoi84,
do u have PE for JGTC 350Z? and spare unwanted radiator grill or intercooler from any kit? and those tiny sport rim with tyre that u dont want? i need to upgrade my suzuki cappucino's 14" TE37.. that too small coz i'm making it wide body. if u got, pls make me an offer. thx
equin0x said:
ayoi84,
Wide Body? You custom made by yourself??? haha
i'll check first "PE for JGTC 350Z". 14" rims haa bro? i dont have lar :( For intercooler u can scratchbuilt by urself.. here is some tips.
Taken from Automotiveforum.com
scratchbuilt intercooler by flyonthewall
Stage one - The face of the intercooler is made from a styrene sheet available from Evergreen which has grooves in it, normally used in rail modeling. This is not thick enough on its own so two 30thou and one 20thou plain styrene sheets were sandwiched together
Stage two - The end pieces are made from 4 triangular shapes cut from 10thou sheet with styrene tubing inbetween.
Stage three - Putty added to fill ends.
The next stage is a bit fiddly so attempt it if your feeling adventurous. Its not really necessary anyway unless your a sucker for small detail - like me
The weld seems are made from two part epoxy putty, the 'toothpaste' kind is impractical.
Small amounts are rolled out.
After placing in position an old large bristle brush is used to create the textur of the weld. Its simply rolled over the slither of putty.
Done! - If you wanted to, you could add more around th pipe and on top but you won't see them so there is little point.
Adding pipes
The purpose of this next stage is to help hide away the empty space behind the front intake of a curbside kit. So carrying this out depends on what model your adding your intercooler to and the size of the visable area.
To make the pipes i'm using aluminium tubing which you should be able to get from good model stores. The smaller size is 1.7mm and the larger size is 2.4 which makes it about right for the 2.5 inch size tubing on the full scale items. This tubing is quite soft and easily cut through with a No11 blade.
The next few pics are self explanatory but if you've sniffed too much glue and/or forgot to wear your respirator today, then i will point out that two lengths of tube are cut as desired with the smaller diameter cut slightly longer. This is so that it will form a plug to slot into the intercooler. They are then simply cut in two after inserting one into the other.
The reason for using metal is obviously for realism, the aluminium tubing can be buffed to a nice shine, so thats what i'm gonna do! I first gave the tube a light sanding with 1500 wet and dry then polished with Autoglym Paint Renovator but any polish will do.
For the next stage i'll show how to add yet more detail to give it that extra realistic look, here's a sneak.
Finishing touches
I used AlcadII Chrome to paint the intercooler, I can't recommend this stuff enough, its just brilliant!
I based this loosely on the Blitz intercooler - I say loosely coz i didnt convert the measurements from the real thing, only sizing it as desired but copying the basic design - so its only fitting to have the blitz logo on it.
I took the logo from thier website, resized it a few times in a photo software package and printed onto some coated paper, then chose the best size.
I laid masking tape over the image before cutting out the letters. This was just to add a little rigidity to the paper. I opted not to stick masking tape directly onto the part for fear of lifting off some of the Alcad and also because it might lose some of its form. The mask was made to be the same height as the part and markings were made in order to position it in the centre. Dont forget the closed parts of the B's!
I lightly airbrushed it with flat black paint, it was only give a few passes to give it a subtle look like on the real thing. It may also be worth trying Tamiya Smoke or a Dark grey for this too.
With the pipes super-glued in place i cut thin strips of tamiya masking tape to form the rubber band connectors (I'm not familiar with the correct terminology so forgive me if thats not what thery are called) which was wrapped around a couple of times. I applied thin CA to the ends to prevent them from lifting.
painted the bands with a flat mid blue. At this stage i applied a heavily thinned wash of satin black into the groves and over the weld seems to bring out the detail.
To recreate the metal bands i used thin strips of Matt Aluminium Bare Metal Foil.
To make the fasteners i used 15amp fuse wire, glued in place with a little more thin CA
The finished product.
:shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked:
WOW.... u guys are so so cool man!!!!
Aiyo. That's scary... haha
GREAT WORK!!! ayoi84.
Waw, i think i wanna learn how to use styrene and putty also. I wanna custom made hot bumper, side skirt, spoiler for my car la! Already got the image.
Im looking for Tamiya Nissan Skyline R34 GTR V-spec II stickers, cause my box doesn't have stickers.
u can try this. last time saw in ToyCity KLCC around RM40-50
i also bought this last time.. :) 1/24 NISMO GT-R V-spec II (ITEM 24258) with NISMO parts
http://www.tamiyausa.com/images/product/212/12608/header_12608.jpg
Tamiya continues to support our high quality model kits with equally high quality detail-up part sets. In addition to precision crafted photo-etched parts, Tamiya’s Detail-Up Parts Series offers high quality detailing parts made from a variety of materials. Use this parts set to “dressup” your 1/24 NISMO Skyline GT-R (V-spec) ITEM 24210 or 1/24 NISMO GT-R V-spec II (ITEM 24258) with NISMO parts.
Set includes
1) White plastic 5-spoke wheels, large diameter brake disks, large diameter muffler end, steering wheel and side skirt parts for the low-down look
2) NISMO Stripe decals for wheel, hood and door sides
3) Use in combination with ITEM 12604 1/24 NISMO R34 GT-R Z-tune Photo-Etched
Parts Set to build a fully tuned up machine
To highly detail ur skyline use ITEM 12604 1/24 NISMO R34 GT-R Z-tune Photo-Etched Parts Set u can buy this item only at Tamiya Underground One Utama RM89.. i've already have it and want to use it for my Nismo GTR 34 Z-tune hehehe
http://www.tamiyausa.com/images/product/212/12604/header_1.jpg
Tamiyas photo-etched parts sets have been extremely popular among modelers searching for that extra detail and perfect finishing touch. Tamiya continues to expand the detail-up parts series this Summer with the GT-R Z-tune photo-etched parts set. *Assembly instructions for each kit includes information on detail-up parts and assembly.
Set includes the following parts:
Photo-etched meshing for intercooler and engine oil cover.
Metal plated muffler end.
Photo-etched intercooler surface and stencil to add label.
Photo-etched rear diff oil cooler and front grille.
Photo-etched brake disks (F & R) and disk mount.
Photo-etched label for professional display quality.
2 Types of photo-etched license plates (A & B).
Carpet sheets for inside car.
NISMO logo sticker.
Nismo r34 GT-R Z-tune
hope my kit will be like this hehehe
http://www.tamiyausa.com/images/product/210/24282/header_1.jpg
let's not divert the topic shall we ya? stick back to scale model kedai potong thread.
anyway scratch building the intercooler is too troublesome for me, i would opt for resin parts if available. coz i got the styrene sheet but that's not the grooved one.
before i forgot, anyone got carbon fibre/kevlar decal sheet for sale?
waaaaaaaa... i'm lookin for that stuff too.. CF decal!!!!
hehe
this is my kedai kereta potong
i got lots of spares
here is what i purchase at singapore for a goo bargain
The rims cost me SD 12.90
Decals SD 24.90
GT WING and photoetch seatbelts SD 19.90
to me it's cheap ! i have another set of crazy modeller seatbelts..if you guys one, PM me..
Write your reply...
