Any sifu know is there anywhere selling those wira bottom engine cover? Like thise conti car have at their bottom of car one.
search for orsen shield. price online should be around RM300++. this one from zhapalang selling at RM310
Wira update.
After changing both cam & crank sensor the car start nicely and didn't mati agn until...... Today.....
Lucky the car can start back without taking the battery wire off. Juz turn the key few time and it start back agn.
After makan breakfast I went back to the workshop,the boss see my car also kepala pening. He unplug all the wire on the ecu and wait for his checking result....
Wira update.
Like bro. Izso mentioned something might be shorting the sensor........
The mechanic had check all my sensor. Everything is running fine.
Today morning it juz suddenly went dead agn. Starting to getting piss by the vdo thingy. Although is nice to use but when it got problem is really haed to know which thing break down. Diagnose also didn't come out any code is quite difficult.
Check your wiring for the sensors leading back to the ecu. If it aint the wiring, it has to be the ecu. Sensors relay information back to the ecu. It's the ecu that makes the decisions.
They had unplug all the socket and wait for an hour(dunno why) and connet them back. I let it idling 30minute while aircond open and it didn't went dead.
Now I am like driving a time bomb. Dunno when the car will went dead again. Hahahahahahaha
If possible just borrow 2 grounding cable and install at engine block and firewall back to battery.
I am thinking its bad grounding. Different driving situation will have different current+grounding demand. During idle, a bad grounding wont pose much problem...on cars laden with electronics, revving the engine with bad grounding will show multiple error code.
With regards to bad grounding, wont that show up more during starting when a large current is drawn? If grounding to engine was suspect, it cant possibly pass through enough amperage to start.
Not totally ruling out grounding. If ecu has bad ground to chassis, then it may cause issues. But that's related to chassis ground and not the engine side
yup it should show up during starting.
since the car is driven over rough surface and wiring is old, possible shaking+ratting damaged of loosen some crimping and caused oxidation.
Grounding sometimes hard to understand. Like got one time was at mechanic place, he was doing an old car. Change rear brake light bulb, step on brakes, ok. Turn on signal the brake light gone. Finally he add a thin ground wire from tail light to car body, everything running fine.......lol
You replaced 2 sensors? Where exactly is the camshaft sensor located on the wira vdo? Did you take any pics? Please share.
The 1st one is cam sensor is at the distributor top there
The 2nd one is crank locate at the bottom one
Mayb I need to find someone know about grounding to help me in this one. Hahhahaha
The ground point at rear trunk is probably rusted. Has enough to power the signal light but not the brake light.
That's similar to my 4G93 but mine has crank sensor there as well.
So, you dont have a picture of the crank sensor at it's location near the crank pulley. Is it inside or outside of the timing case?
Yup,the crank sensor is locate near the cranj pulley. Vdo have a gear shape thingy attached to the crank pulley.
A thread every 60 seconds
