coilovers
Ok! Will pay a visit after this MCO. Thanks!
Currently I am using rims from Evo7. not sure what is ARB connections.. sorry me noob.
ARB = Anti roll bar.
Sounds like like you got a pretty straight forward PNP installation. What brakes are these again?
Reactions: NJK
lsm1991
1,469
185
driveshaft maybe ok coz airtrek most stuff should be pnp with evo 7.
omg it just occurred to me, he didnt really say he was going for evo brembos.....
if hes going for aftermarket brakes theres little point of going for evo knuckles (unless those are evo pnp brakes)
Reactions: NJK
NJK
Jul 29, 2018
2
my appologize bros, yes, eyeing on Evo7 brembo. but not sure to go with bracket or straight change with knuckle, shaft etc. :)
sanekit
Dec 9, 2015
1,616
157
ah ok. if like that u will need the knuckle and the driveshaft. did some search on other forums, evo driveshaft is a bit larger than airtrek so not direct pnp on the knuckle. if u just swap the calipers, just like u said, you will need brackets. but cheapest option is caliper and brackets.
Reactions: NJK
NJK
Jul 29, 2018
2
Ok, thanks for the info bro!
Reactions: sanekit
4gbanger
1,958
386
1,683
Johor/ShahAlam
u gonna need the evo front driveshaft and steering rack in order to install evo knuckle. everything else can use back airtrek parts. for the rear brembo, need to mod abit at hole to install at airtrek knuckle. hope this helps.
Reactions: sanekit and NJK
NJK
Jul 29, 2018
2
Thanks bro! decided to go with bracket. installing soon.
Reactions: sanekit
I have replaced my 6A12 auto box with a recond unit 3 months ago. Lately the gearbox experiences a judder occasionally whenever I release the accelerator pedal. Since the gearbox is still under warranty, I sent it back to the gearbox specialist for diagnostics. After some road testing and tinkering with scan tool, it was found that the ATF temp at oil cooler is abnormally high at 93 degree. He said there was a some clogs in the oil cooler, so he flushed it and have the gearbox TFT sensor...
