Regarding lower arm, the correct way of tightening the bolt is to do it when the car is at its rest position and not when the arm is extended to its lower position which most shop does as its easier to access when the car is jacked up.After working back home and.....
Car part arrived!!!!
Order on 29 Oct received today quite fast.
Tomorrow will go to my workshop to swap my disk rotor & full set of control arm.
i've seen worst...all thats left are just the backing plate. Best part is how the owner describe the issue 'aku brek brenti je tp ade bunyi'.Wira update
I juz pass by the shop so juz walk in and check my car. Walao,the brake pad holy shxt. I really want to tembak the shop who service my car. I told hin to hlp me check the brake pad and he say still got a lot. Wa,boss your alot is how much ah?
The other picture is the old Lower arm compare with the new arm.
Anyway, better to check the condition of yr disc if its got too much groove or too thin or already got super high lip.
Just odd that you didnt notice when you bought the car. Btw, is your company mobile? You mentioned driving it backBoth plate & pad are dead. Totally dead. Juz throw my car at the workshop and drive my company back home.Hahahahaha
I have lubang for Superpro. The prices you see online are RRP. Mines slightly cheaper. But cheapest option atm is still rubber and new rubber is still pretty solid.
It's quite unfortunate. Seller wasnt that truthful either.When bought the car it didn't have any sound. And the freaking bbs rim design is hard to see the rotor & pad. I hate the wheel so much omg.
I work at Construction site. They have a Nissan Frontier since I don't have car so I juz drive back.Hahahaaha
Serious? Previous owner drive without problem or he/she park the car only. ?I think the seller doesn't even know. Hahahaha.
I would like to ask a stupid question.
4g15 can slam a 4g93 auto gearbox in it?
Juz curious only since 1 is 3 speed 1 is 4 speed.
Sadly, u can't. it'll cost a lot to swap oso iinm. EDITS: after some research, reason is the 4 speed auto uses transmission control unit which is not compatible with the siemens ecu. maybe u can ask your mech if it's doable. if can, do install an atf cooler for the 4 speed auto.
swap 4g92 or 4g93 single cam jer. if got extra can go for 4g93 dohc, and BOT after that. hehe
Survey before.
Half cut 4g93 1.8 soch cost around RM4800
Installation RM1500
Total RM6800 is quite some money there.....
Even if I swap it they don't makan your old engine & gearbox is quite pain in the axs. Also need space to store it & sell it. I dunno why Johor halfcut quite mahal.
In KL, 5k you can get Satria Gti engine complete from half cut.
Bro KHNG940413, if you are contemplating engine/gearbox change, I have to ask you what's left of the old car which you havent replaced. What's left?
* Alternator
* Steering rack
* Drive shafts
* Power steering pump
* Exhaust system
What else ?
You do realise that apart from the rear trailing arms, you have replaced your entire undercarriage including the wheels/rims.I think the thing you list is the thing I haven't chg.
Hahahahahaha
Other then that I really change already.
Similar threads | |
