[WTA] Recommend a car body repair/paint shop in PJ area
lsm1991
1,469
185
kay...
yeah. price is quoted based on 085-Sonic Quartz Metallic to spray the whole car inside and outside for 7 layers. It will including some knocking for dents and rust (if there is).
let price;
console.log('085-Sonic Quartz Metallic costs ' + price);
: 085-Sonic Quartz Metallic costs undefined
parakey
1,367
226
oppsss... miss that info... no wonder all of you blur blur liao...
quoted 2.8k. reasonable?
2.8K sounds like a good price for spraying inside/out. Does that include the engine bay and trunk? But why 7 layers? Where is this paint shop?0
Never heard of 7 layer spraying. Unless need primer, probably 2 layers of paint and a layer of clear coat.....:dontknow:
Not sure if you can layer clear coat over clear coat. Too much at one go also cannot , it will create runs
I watched on tv before the guys do wet sanding on the clear coat they apply before applying another layer of clear coat.
The finished job looks great. Then again, its a tv show so everything is great.
Hello frenz,
I have some problem with my car engine. :hmmmm:
It will jerk/turn off while still moving when I press the clutch to shift from high gear to low gear and when slow down at trafic light. It happen quite frequent unless if I keep on accelerating the engine. This only happen when I turn on the aircond.
Fyi, I'm using engine Silvertop 20V that fix into toyota AE111.
Appreciate your help/idea on how to solve this problem.
Thank you.
