Bridgestone RE002 or Toyo T1R Feedback
How is PS3 compared to RE002? Performance potenza are always overpriced for me
Agree, I also feel BS tires especially Potenza are too overpriced already (ever since they dominated F1 last time). In most of the reviews I read, their top performance tires are also so-so only and always beaten by other top performer like PS3, CSC5, F1. So for me BS is one of the last choice I'd consider in buying tires now. The last time I used BS was probably >15yrs ago which was the 1st Potenza for Indonesia market!
PS3 over budget. ATR Sports 2 it is..set and locked on :smokin:
Buy cheap rims and expensive tyre mah! Not expensive rims and cheap tyre........hhahhahahahaha:biggrin:
---------- Post added at 09:34 PM ---------- 6 hour anti-bump limit - Previous post was at 09:34 PM ----------
From Hup Shun? :biggrin:
He go Rawang and Klang......:driver:
I wonder how much id R1R over there? :driver:
Exactly! My tires also cost more than my used rims!
If can buy expensive rims than should also be able to buy corresponding expensive tires!
OE! OE! OE! ahahahaha
My VR and Hyundai also second hand rims woh! But can say tyres not bad.....:biggrin:
You guys keep saying BS tyres...I keep thinking BullShit Tyres :rofl: :rofl: :rofl:
From PTS, seems majority feedback achilles is cheap there since they are the distributor for Achilles.
Rims one time off ma. I won't be changing rims so often like tyres. Anyway also since got good review. If it is cheap and good. Is worth a try ma :rofl:
Unless I can get a really good condition 2nd hand rims. I wouldn't mind as long it looks good.
Advanti for a new and lightweight rim, price is reasonable.
But if there are any good 2nd hand, I would take it rather than spending too much on rims.
ATR Sports 2 have not tried before, so cannot comment too much.
Get Bro. Izso to sell to you......hhahahhahahaha:biggrin:
now i on 195/55/15 tire but original size is 185/60/15 and now i wan change to 205/45/17 is it ok?
Can be used, as it is 2.21% bigger only. But being much wider check your wheel arch clearance for the rear and turning circle for the front, if you have lowered suspension and/or rim offset that are too out.
ok...it will make my car feel heavier and more fuel consumption?but i dint lowered my suspension,all is original 1 i think it will no problem and i plan to use re002 but it is xl...
any different xl and normal?
---------- Post added at 09:05 PM ---------- 6 hour anti-bump limit - Previous post was at 09:04 PM ----------
---------- Post added at 09:05 PM ---------- 6 hour anti-bump limit - Previous post was at 09:05 PM ----------
Should affect fuel consumption because you might step more on the accelerator because pick up will be decreased due to higher gearing from bigger wheels. Why not get 15 inch re002?
because now i on 195/55/15 Ps3 and i plan upgrade up 17'' rims but the price of ps3 17'' too high so i plan use re002...bcoz 15'' rim i think not so stable for high speed and 17'' looks more good haha...and i dun know the 55 series for ps3 is too high for the soft sidewall bcoz when high speed it not stable feels like blow by wind
Eh? I thought RE002 is even more expensive than PS3? Im on 15 inch stock internals too. Seems fine to me so far. You can go 17 if you want,but it definitely slows your acceleration. Also iirc 245/45/17 is quite thin sidewall? Might want to slow down when seeing bumps and potholes. :biggrin:
haha...if 15'' re002 and ps3 price alsmost same,but when reach 17'' the price different ps3 price quite high for the size...when see bumps need slow slow to across the bumps or not damage the rims right?but i not use 245/45/17 just 205/45/17 my car is small sedan car only i think 245/45/17 cannot suit my car...i quite intrest re002 dun know how it perform...actualy i thinking few tyres like csc5,toyo drb,federal 595evo,
haha...when see bumps need slow slow to across the bumps or not damage the rims right?but i not use 245/45/17 just 205/45/17 my car is small sedan car only i think 245/45/17 cannot suit my car...i quite intrest re002 dun know how it perform...actualy i thinking few tyres like csc5,toyo drb,federal 595evo,
Not just damaging rims, your ride will be bumpy from low sidewalls. As far as I know, re002 can be compared with t1r and 595evo. Not sure about csc5 though. Im using a set myself. Its good. No complains so far. Heard the rain grip starts to get bad after like 50% use. :driver:
ic...u just change re002?how many kms you are running until now?is it grip good?will it wear fast?,bcoz i see many comment say re002 wear very fast,and my friend told me re002 wear can last longer than t1r and grip better than 595evo...hmm...i think for 45 series i still can accept
Write your reply...
