Maximum size of slotted brakes for a 16 inch
GearSpeedKelvo
167
10
Philippines
What is the maxmium size of a slotted brakes for the front for a 16 inch wheels on an AE111?
What about the rear slotted brakes?
Thanks
Mr.Chaser
4,065
184
Johor
The max u can upgrade for front with 16inch rim=303mm rotor with single pot caliper. If twin pot, max around 292mm-295mm!
GearSpeedKelvo
167
10
Philippines
How about the rear?what's the maximum size?
Thanks.
Mr.Chaser
4,065
184
Johor
Share mine upgraded 292mm brake kit!
GearSpeedKelvo
167
10
Philippines
I tried asking the branded ones but they said there is no parts that can fit for an AE111.
If there is someone who went slotted here what is the part number of the slotted brakes you purchased?
What brand did you use?
I wanted either made in U.S and Japan brands no china made ones.
Thanks.
Mr.Chaser
4,065
184
Johor
me2kimi
717
276
1,563
Puchong
Wow! Nice mod there
Sent from my Galaxy Nexus
sky910
260
7
3,018
mind share with me how much does it cost to making floating disc?
Mr.Chaser
4,065
184
Johor
There you are our disc brake casanova Mr Chaser. Beware of his poison too.
Hahaha, i though Sharing= Caring mah :p
Okok. More n more poison to come!
VttR 303mm sports rotor pcd 100× 4
Mr.Chaser
4,065
184
Johor
Happy New Year 2014 to ALL!
Corolla's AE101 with aftermarket mini 6 pot & Tom's sticker + shinning Yellow :driver:
Mr.Chaser
4,065
184
Johor
hi 2 all sifus!
quite sure this problem has been discussed b4 in the forums but lazy 2 search 4 it plus mine i'm sure a bit different perhaps??? anyways 2 sum it all up, my car's idling is VERY bad. cold start in morning impossible 2 start cos when i do, rpm will immediately fall after 2 or 3 seconds after car starts then engine mati. so i gotta start n press gas 4 awhile then idle stabilises somewhat... even when the engine dun mati rite the idle goes up n down around 500-1000rpm like tat...
