which brand of 195/55/15?
7jj front is okay with 195/55/15 but proper fitment for 8jj should be 205/55/15.
Unless you want some hellaflush look but less practicality.
Achilles ATR sports fit your budget. Falken ZE-522 sucks in wet but it may fit your budget too.
Michelin PS3 already cost 240 apiece.
which brand of 195/55/15 do you all suggest? is going to fit 8jj or 7jj..
budget around RM180 each..
Actually, there are very few choices of 195/55/15 size tyres that you can get with RM180 budget nowadays. IMHO, consider spend a few ringgit more to get decent tyres. It's worth the investment, really.
I think Falken may have that size...
Is it for Proton Wira SE ?:confused:
its for wira sedan...
---------- Post added at 01:26 AM ---------- 6 hour anti-bump limit - Previous post was at 01:21 AM ----------
in fact i'm going to ply some hellaflush look hehe..still considering 7 or 8jj and what brand of tyres..
I heard about some cognitive dissonances about Falken ZE-522..but naver heard about Achilles ATR sports haha..whats brand is that? is it good to be used?:adore:
---------- Post added at 01:28 AM ---------- 6 hour anti-bump limit - Previous post was at 01:26 AM ----------
I know that there are few choices of 195/55/15 in the market but just don't know which to choose/\
Will consider your suggestion, thanks:biggrin:
Kumho KU31 or Achilles ATR Sports gets my vote
Achilles is the Brand....:biggrin:
---------- Post added at 03:58 PM ---------- 6 hour anti-bump limit - Previous post was at 03:56 PM ----------
KU31 is now cheap.....
hw about Toyo Proxes T1R and Bridgestone Turanza ER300? I heard about their price today and i feel like is kinda worth:biggrin:
are they good to be used? which 1 is better? if i using 195/50/15 8jj will it be not comfortable?
open for all type of opinions :adore:
T1R is okay but I have never try ER300, so, couldn't comment. As for the Indo made Achilles ATR Sports, I used to use it for a few round of drift last time with no issue.
Overly done negative camber setting on Hellaflush style kill off the comfort. One have to give way.
195/50/15 on TE37 or CE28 hellaflush look should be okay on Wira sedan.
I am also currently considering rota style wheels but not hellaflush looks as I prefer practicality.
comfortable??? no it will not be comfortable...u wanna do this kinda mods, comfort is the last thing that should be in ur mind...
and T1R sidewall is soft, so should have a lil more comfort if u really want it...
ER300 no idea
why dont get xm2?
Dear Kendrick92,
Toyo tyres no comment.
Bridgestone Turanza is a good tyre, very silent, comfort and good grips...
But be careful, watch out the manufactured date at the sidewall,
Very likely it could be the 2007 or 2008 year stock.
(Lifespan is 5 years only):burnout:
ER300 no idea
No matter what tyres we used, hellaflush will never be comfortable. I can't even take corners properly with them :biggrin:
In fact, most of my friend only put on the hellaflush looks during autoshow. They have another set of wheels with standard camber setting for daily ride.
Offset wheels on rota grid is fine. Just make sure to put on the correct tyre width / spacer / fender works to get the handling part.
Dear Kendrick92,
the manufactured date of Turanza is stated as week 23 of yr2012 haha, bt Toyo Proxes T1R is week 47 yr2011= =are they considered ok?:hmmmm:
---------- Post added at 02:16 PM ---------- 6 hour anti-bump limit - Previous post was at 02:11 PM ----------
Hi there, actually i'm going to use te37 rota grid on my wira..is it 195/50/15 ok to be used? will going to do some fender work after install these tyres..or 195/55/15 better? :adore:
Toyo T1-R is UHP, good for aquaplane resistance, however soft sidewall and dry grip so so only.
BS Turanza as it is name is mid range tyre. Their Potenza range are more to performance.
---------- Post added at 03:59 PM ---------- 6 hour anti-bump limit - Previous post was at 03:55 PM ----------
Wira if no engine mod 195/50R15 will be better, diameter closer to original size. If want fuller look without lowering then 195/55R15 will fill up the wheel arch but pick up may suffer a little.
