In this thread I will show how I modified 5 hole disc to 4 hole and fit it into my AE111. Since my brother left his DC5 disc at my house, I will use his disc to fit into my car.
This is tool that I use beside of the hand drill
Here is picture of original disc
Disc marked before drill
And here is 4 hole already drilled
To fit the disc into my car, firstly took out tyre and rim then took out caliper. Here is the picture in the process.
Before started
By using this type of clamp, I push the brake pad further away so that easier when to install new disc
Remove this 2 screws that hold caliper
Then I hang the caliper to avoid caliper hanging only with brake hose
Test to fit modified disc rotor
Cheap brake pad that I used
New brake pad install
Then install back caliper into knuckle
Comparison before and after
Put wheel and ready to go.
p/s:before that make sure continuously pump brake until feel brake pad grip and check brake fluid level before start driving
As seen on me2kimi.blogspot.com
Before started
