When will you do your car aircond check-up?
Normally if you go service your air-cond. unscrupulous poreman will spray strong alkeline on your cooling coil for cleaning purposes.
But this process will also cause the thin manbrane to kena hakis and leak. End up need to change cooling coil.
When?
When the aircond is no longer cold.. ahhahaha
Mine still cold but takes more time to cool the cabin up. Especially if parked under hot sun. Wanted to service but got distracted by so many other things i.e. change suspension, disc brakes conversion etc..
Similar threads | |
F |
Similar threads | |
