wagyu
Hi, so the powder coat are safe to use it on caliper? Can quote me price for red powder coat for one pair of caliper? And how long you need to coat it?
Many thanks
Many thanks
Many thanks
Hi bro, yes it is safe. Price rm80-120 per pcs depend on size and color. U have to remove all the pistons and seals before send to us. Usually take 2 days to finish.
Thank you.
---------- Post added at 02:11 PM ---------- 6 hour anti-bump limit - Previous post was at 10:24 AM ----------
Kawasaki Green (campro vc)
Blue Starlight (cps vc)
My calipers can't remove the seal, not recomand to remove it in fact. And I know that the seal can't over heat, if you need to put it in high temp in order to coat it, I guess that's cannot be done for my calipers.
So sad.
hurmmm, mind to share what caliper is that?
just wondering why the seals cannot be replaced
Salam bro,
For the IM, if ceramic coating doesn't work can it be removed via sandblasting? Still thinking to do it for my MCS based on reason I have a 200degC SC right under the IM boiling the air inside. The heat is localized in one area which directly above the SC at the moment.
p/s: the intake and exhaust manifold is not mine
Waqyu,
There should be service kit available for that calipers based on realoem. Just ring BA if they carry such kits.
Salam bro,
Waqyu,
Bro..how much for Red Wrinkle for Valve cover? Red for calipers also? Can i go direct to your place and do it in one day?
boss...whats the different between matte blue and blue wrinkle...??intersted for it
How much and how long does it gonna take..??
Thanks
when you powdercoat the rims, would it still be possible to have the lip uncoated for that shiny effect?
---------- Post added at 09:52 PM ---------- 6 hour anti-bump limit - Previous post was at 09:20 PM ----------
this is the rim i am talking about.
do you need to remove the old silver paint?
can you keep the spokes and lip polished??
http://i280.photobucket.com/albums/kk177/pupjoint1/pupjoint2/afterinstall6.jpg
now wan to find halfcut with body part to repair,anyone know where can get it?
