can you install Bee R rev limiter on carburator cars
sam999998
hi guys
iv got a satria 1.3 carburator engine (4g13) was planning to buy the Bee R rev limiter .can any1 tell me if i could install the rev limiter on a carburator engine like mine? if yes can u explain me how and all info i should no.....
i think cannot..coz carb cars hv no computer box
why you want to install?
carb hv no rev limit...can lenjan kaw2 hehehe
i think carb has it's own rev limit.. although it's hard to get the setting..
u can try when u r in 3rd gear.. floor the throttle & see how high it can go..
i don't think it'll pass 8k rpm
:biggrin:
ZERODET- you are ryt i have no rev limit on my carb satria ....which is good but as u no Bee R rev limiter is just nice....i mean those loud bang sounds .Thanks for ur help guys but i have another question...which has always been here BOT on carb engines !!! i no its possible but can u plz direct me 2 any1 who can do it.
sam...carb with bolt on turbo
possible but not advisable
coz will eat ur petrol like water flowing into drain hehehe
tuning problem also...
not recommended at all....
better change to turbo engine!!
PROTON CARB ENGINES SUCK ...better have a vw beetle !!! hahaha nway im satisfied with my 1.3 engine ..mods done
* adjustable light weight cam pulley
*high cam
*piston bore enlarged
*JASMA 2 core radiator with all round samco pipings
*cold air intake system with electric turbo fan
*mitsu lancer disc brake front n rear
*customized extractor and exhaust system
*light weight carbon fibre bonnet
*light weight acing clutch
plus many little thngs to mention
need more advice wat mre can i do ...dnt wan change block or wat so eva .....
need advice if can put bee r rev limiter or not..and how the connection
*high cam
what the electric turbo fan can do? im curious........
Try to push more air in.......:biggrin:
But NA sucks in not get pushed in.......
---------- Post added at 05:00 PM ---------- 6 hour anti-bump limit - Previous post was at 04:58 PM ----------
If he wants the power, petrol I think is the least of the problem.
How to tune to get the correct fuel feed?
Mechanic will ask your to drop in a turbo engine better......:biggrin:
