[WTS] Shift Lights
[WTS] Shift Lights
  • Thread starter Indecided
  • Start date
  • Reply 171
I
Indecided
Guest
Wow. barely a day and so many replies!
Anyways, the sample unit should be with me by next week hopefully.
To answer the questions :
chichaq, yes you can use them on 3cyl cars. in fact, it works for all single-fire ignition systems. (dual fire... sorrylah :P) I'm not sure if it's specific or ordered specially.
The techincal specs i have give the dimensions roughly simillar to a pivot unit. the LED unit is housed in a plastic/metal case with mounting options being double sided tape. it's like the SMALL pivot shift lights...
I will get back to u guys as soon as possible :)\
alantan
3,573
15
kl
i;m quie interested la...
heehe
1000cc..carbie 3 cylinders...
what rpm?
I
Indecided
Guest
shift lights are universal, you can tap your tacho signal from either the ECU (EFi) or negative ignition terminal (distributor). Of course the ECU is normally cleaner.
I'm running on a carb myself and if you can run a tacho, you can run this.
Will keep you guys updated.
Anyways, keep posting :)
sbd18
130
i want one too...rm100 is just great...100RPM would be good...better setting... :D
anion
1,083
76
5,148
indecided.....updates ! updates ! hahahaha....wanna get one liaoz.....
L200s
37
3,008
haha....indecided...so many wan to buy liao..wut r u waiting for...i oso want too....
I
Indecided
Guest
Ahhh..so many replies....
Colors available are RED,BLUE (flashing or non-flashing hardware option)
other colors are WHITE, GREEN, ORANGE, PURPLE. other colors available on request.. but MINIMUM 2 per color i was told. I need to take a batch of 20..
so people.. i will be requesting for 100RPM stepping, range will likely be from 2500 - 6500RPM... details will be confirmed later.
:) cheers
Can HKS SSQV suite for use on K-CAR.
My case Kelisa bolt-on with 0.6/7 bar.
SSQV suite to use or not..? the bov sound wiLL "QIU QIU" or not.
k-car owner plz share experience, thanks~~~
