[WTS] Chemlube 100% Syncthetic with Ester Based
Kent_Goh
1,493
50
1,648
www.xd-auto.com
[WTS] Chemlube 100% Sync Ester Eng & Gear Oil
CHEMLUBE fully synthetic oil is available in 3 viscosity grades - 10W30, 10W40 & 20W50. These organic ester multigrade full synthetic oils are specifically designed to meet the demanding hot climate in Malaysia and Singapore. CHEMLUBE organic ester fully synthetic oils meet and exceed API SM-CF, MIL-L-46152B. They are recommended for use in all gasoline and diesel engines. The low sulphur content of CHEMLUBE
Ester synthetic oil is a highly desirable feature for use in turbo and diesel engines. The inherent characteristics of organic ester synthetics provide for low evaporation rates and strong detergent to keep engines clean of sludge and carbon. CHEMLUBE has the highest viscosity index of 197 giving oil stability for complete lubrication during traffic jams and sustained high speed driving. Engines run cooler with CHEMLUBE.
Engines using CHEMLUBE are significantly quieter, have better response and improved fuel consumption of about 10%. CHEMLUBE oil film strength of over 3000psi far exceeds other lubricants. Esters natural affinity to metal provides for an oil film on all metal surfaces over prolonged periods of time and gives easy early morning starts. CHEMLUBE long life synthetic oil is recommended for 40,000km or 1-year oil change intervals in normal driving conditions.
*1 Quart = 0.946Litres
Chemlube 100% Synthetic Organic Ester Base Oil
10W/30 - Rm52.00/Quart
10W/40 - Rm50.00/Quart
20W/50 - Rm49.00/Quart
Chemlube 100% Organic Ester Base Fully Synthetic Sport Engine Oil SAE30
CHEMLUBE Fully Synthetic Sport Engine Oil is available in 1 viscosity grades - SAE30 & SAE40. These organic ester multigrade fully synthetic oils are specifically designed to meet the demanding hot climate in Malaysia and Singapore. CHEMLUBE organic ester fully synthetic oils meet and exceed API SM-CF, MIL-L-46152B. They are recommended for use in all gasoline and diesel engines. The low sulfur content of CHEMLUBE
SAE30 - Rm75.00/Quart
SAE40 - Rm75.00/Quart
CHEMLUBE fully synthetic gear oil and these organic ester multigrade full synthetic oils are specifically designed to meet the demanding hot climate in Malaysia and Singapore. CHEMLUBE organic ester fully synthetic gear oils meet and exceed API SM-CF, MIL-L-46152B. They are recommended for use in any manual transmission beside LSD. The low sulfur content of CHEMLUBE
Ester synthetic oil is a highly desirable feature for use in turbo and diesel engines. The inherent characteristics of organic ester synthetics provide for low evaporation rates and strong detergent to keep your transmission clean of sludge and carbon. CHEMLUBE has the highest viscosity index of 197 giving oil stability for complete lubrication during traffic jams and sustained high speed driving. Gear box run smoother and cooler with CHEMLUBE.
- High performance gear oil
- Superior wear protection under severe load conditions
- Reduces internal hear friction
- Experience a more positive, smoother shifting gearbox
- Chemlube gear oil is designed for use in differential and manual transmission where the ultimate in high performance is required
Chemlube 100% Organic Ester Base Gear Oil
85W/90 - Rm89.00/Quart
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website: www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: http://wikimapia.org/#lat=3.2139519&lon=101.6382739&z=18&l=0&m=m&search=win hong auto
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newfor...331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newfor...2721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newfor...s-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
Kent_Goh
1,493
50
1,648
www.xd-auto.com
thanks for the bump
Kent_Goh
1,493
50
1,648
www.xd-auto.com
thanks for the bump
Kent_Goh
1,493
50
1,648
www.xd-auto.com
enjoy the oil, thanks for supporting me bro
b
u
m
p
EvolutionZ
5,000 RPM
5,027
1,448
great oil...being around for many years.....remembered using it in 1996, but due to budget constraint, stop using........way back its metal can packing
20-50w evo can use ah....worry too heavy
Kent_Goh
1,493
50
1,648
www.xd-auto.com
no problem bro, can mix with 10w/40. 2 bottle + 2 bottle = 15w/45
Kent_Goh
1,493
50
1,648
www.xd-auto.com
I got a friend driving honda dc5 too, he using 10w40.
Kent_Goh
1,493
50
1,648
www.xd-auto.com
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368 / Celcom 9 - 266 8138 . This is to ensure better tracking and a more efficient follow up.
Regards,
KentGoh
kianhao123
110
518
Nice oil!
Free bump fore u bro
---------- Post added at 09:30 PM ---------- 6 hour anti-bump limit - Previous post was at 09:30 PM ----------
Nice oil!
Free bump for u bro
I just want to know, how do u guys time the 0-100kmh performance on your car? Besides a complete stop before the timer has started, r u allowed to rev your engine before the stopwatch is started?
Just tried it a few hours ago with a friend holding a stopwatch along Kota Damansara. Car was at stanstill without revving the engine before the timer started. REally lousy results...heheh
Specs :- 1.8 4G93p sohc manual w/16in rims wira
1st time - Tire spin & lost grip due to wet road on 1st...
