dont get like mine using right now..clearance sure a problem..Agree with bro. slipar, got many brands. Get the one that fits proper...
properly design extractor dont have clearance issue bro..
many extractor now in market..just choose the right one..
Oh, I thought when change extractor, this problem will occur regardless of the brand. Now only I know...Agree with bro. slipar, got many brands. Get the one that fits proper...
i was thinking to DIY it without taking out d extractor. if too many hassle then have to go to workshop la.Can be done if you want a shitty job. Very little space to move around, the mechanic or person doing it will curse you forever
The extractor is very easy to remove. If your exhaust isn't welded to your flexible pipe / catcon, then you can just buy a exhaust gasket, remove the bolts and nuts, then can take some time to clean the exhaust ports too.i was thinking to DIY it without taking out d extractor. if too many hassle then have to go to workshop la.
Bro., your extractor really out leh! I thought only fan clearance. Oil sump also....dont get like mine using right now..clearance sure a problem..
clearance with rad fan issue..really just few mm only..sometime when engine rocks extractor touch the motor fan..hahah ..then clearance with lower oil sump also got issue..have to knock a bit oil sump to got the gap..the gap like only thickness of 50cent coin..or it just me got this problem using this extractor..
really out for my car..maybe the extractor build using measurement for 4g92 not 93..Bro., your extractor really out leh! I thought only fan clearance. Oil sump also....
You bought and fit yourself? If not, sure you can reject if need to knock here and there...really out for my car..maybe the extractor build using measurement for 4g92 not 93..
some more 1 piece type..really hassle just to install or dismantle from engine..have to cilok here n there just to put the extractor in place..hahaha..but the performance for sure la better then standard gti extractor im using before according to my butt dyno only..
the shop dont provide installation..just sell only..You bought and fit yourself? If not, sure you can reject if need to knock here and there...
that correct..if its not broke im just leave it as it be..Already fitted so just leave it. Only thing is extractor too near the fan....
