Hi All,
I need some advice on my WiSE (Wira Special Edition). I am driving the WiSE (MT). My stock absorbers sudah kaput ready after 90K km. I need to change it already.
Can anyone the sifoos suggest a good set of absorbers & springs? I don't want to use back stock stuff la. The reason i want to mod is because slowly i want convert my engine to GSR 1.8T. Maybe next year tukar engine la!
So stage 1 is :
1. Change Absorbers & Spring
2. Convert my drum brakes to Disc Brakes.
For Point #1,
My budget is rm1000 for absorbers & spring. One of my colleagues(whose is a car guru) suggested Eibach Pro Kit Spring with KYB standard absorbers.
My main concern is to have 30% comfort while 70% Handling. This should also cover my engine conversion later next year. Meaning the absorbers & spring must tahan the 1.8T GSR engine & speed la. I don't want to change my suspension system all over again. no $$$ la! :)
For Point #2
I visited one of the Chop Shops in Puchong. I went hunting for Wira 1.6 or Satria GTi rear disc brakes with the handbrake cable. They said no stock & its expensive.
Alternatively they suggested to use Honda Civic Discs & Caliper with Wira under bar. Meaning the only thing different is the Discs & Caliper. Otherwise its all Wira Stuff. Its a recon set in which comes with the handbrake cable. So practically my discs will be honda civic in which they(choppers) quoted easier to get spare parts like discs & brakes. I am not sure about this. They even said its Plug & Play!
So in truth, i am confused & worried. Can you please give me your 2cents worth on this matter?
thank you
arun
So stage 1 is :
For Point #1,
For Point #2
thank you
arun
