the housing is wrapped so i cant see...if i measure it how big should the diameter be for a t04r?It should be stamped on the housing. Or you can do a manual calculation by measuring the exhaust side diameter
400, 460 and 490hp depending on the trim - 54mm, 57mm and 60mm respectively.any one know how much horse a T04E is capable of? and it is a good turbo?
I bought the car abt 3 months back, came with the single conversion..done by the 2nd owner so even the person i bought it from doesn't know...some ppl are saying its a to4r while others t04e but i have no idea...maybe i should just ask the previous mechanics...Uh oh, just did a check and I am mistaken. They stamp the AR on the housing. I have no idea how you find out the trim unless you bought it that way. Will let you know if I find out.
Trim refers to the relationship between inducer of the compressor wheel against the exducer of the turbine wheel.
You can read more here:
TurboByGarrett.com - Turbo Tech102
Your life would be easier if you had a Garrett turbo coz you can calculate the trim from the 4 digits.
---------- Post added at 02:22 AM ---------- Previous post was at 02:09 AM ----------
As for whether it is a good turbo, it really depends on your application. If you stick a big turbo on a small engine and get no boost, will you say that the turbo is bad?
Thanks Joe. Its good to know that...hahaThe 2nd previous owner bought the turbo kit from a member in Melaka. Confirmed is TO4R.
I don't need that much power but 400+ would be nice. Right now I'm only running slightly above 300 at 0.8 bar. Will there be any issues with running that low boost? I have a boost controller which i can set to 1 bar, it that any different to having it re tuned to 1 bar?Gah! T04R is maxes at 700HP.
Do you really need all that power? I think you would be able to get 400HP flywheel at 1bar for a rotary with the usual mods.
i know its 300 because the previous owner tuned it down to 300 (previously it was tuned to around 460 by the owner before him, but i don't know at how much boost)..so i would guess that would mean 300 on the dyno...which would mean more on the fly wheel right?Question: How do you know you are putting out 300HP at 0.8 bar? And is that wheel HP or flywheel?
Assuming that 300 RWHP, it means that the flywheel is producing 375HP - with 20% loss at the wheel. That's pretty close to 400HP at the flywheel. Doesnt sound any problem to hit 400HP at the flywheel at 1 bar then.
