Turbo manifold design
l2s_turbo
1,068
154
Hi bros, can anyone recommend me the best turbo manifold design for an auto driven car? I've heard some says the banana type doesn't suit the auto trans because it'll cause a bit of lag.. i've also seen other type of manifold like those super lengthy pipe design den end with the collector like those WRC type.. so lets discuss this over here..
---------- Post added at 05:54 PM ---------- 6 hour anti-bump limit - Previous post was at 03:58 PM ----------
Also about material used, which type of material is better?
l2s_turbo
1,068
154
Can any sifu help to advice here??? :adore::adore:
karl_razlie
514
56
5,028
Puchong
intake manifold or exhaust manifold???
---------- Post added at 02:30 PM ---------- 6 hour anti-bump limit - Previous post was at 02:29 PM ----------
for intake manifold (custom) read this:
The Intake Manifold
While it's not easy to modify an existing intake manifold because it requires specialized aluminum welding, this section will discuss what to look out for when choosing an aftermarket intake manifold, or having your existing intake manifold modified. The intake manifold actually consists of two distinct parts that can be tuned separately. The two parts are:
the plenum, which is an air chamber that distributes air to the various cylinders
the intake manifold runners, which connect each cylinder to the plenum
THE PLENUM
The main purpose of the plenum is to equalize the air flow to the various cylinders, but its volume and shape, as well as the shape of the bell mouths, which are the opening to the runners, are also important. Generally, a plenum volume of approximately 80% of engine capacity for naturally aspirated engines to 150% of engine capacity for turbocharged engines works best.
In terms of function, the best plenum design would have the air duct feed the center of the plenum. Unfortunately, due to space limitations and production costs, manufacturers tend to build plenums that are fed from one end, with the plenum blocked off at the other end. This results in air rushing to the far end of the plenum and creates a slight imbalance of air flow to the individual cylinders are the air will tend to flow past the first cylinder and collect at the far end of the cylinder, which is usually at the last cylinder. Consequently, the first cylinder will run slightly lean while the last cylinder will run slightly rich.
The easiest solution to this problem is to fit a second throttle body to the far end of the plenum and fit a double air filter, intake system. But this only works on naturally aspirated engines that have sufficient space for a second intake system. On supercharged and turbocharged engines this solution is not feasible and you would need to modify the plenum or fit an aftermarket intake manifold with a more efficient air flow and air distribution design. There are three things you must consider when modifying the plenum or selecting an aftermarket intake manifold.
First, the plenum should increase in size rapidly well before the first cylinder.
Second, the plenum can taper towards the end from after the first cylinder but it should not taper to less than 1½ times the diameter of the intake runners.
Third, the plenum should extend well beyond the last cylinder.
INTAKE RUNNERS
As is the case with the primary exhaust pipes, the diameter and length of the intake manifold runners influence the power curve of the engine. The intake runner diameter influences the point at which peak power is reached while the intake runner length will influence the amount of power available at high and low RPM.
A larger diameter intake runner, relative to the diameter of the intake valve, will result in improved engine breathing at high RPM and will take peak engine power to a higher RPM but will have little low RPM power. This may be good for a modified race car or a drag car, but will not be good for a turbocharged car with a large turbocharger. For a good responsive modified street car or a rally car you would want an intake manifold runner diameter that is approximately 80% the size of the intake valve diameter on a two-valve cylinder, or the same size as the intake valve diameter on a four-valve cylinder, as this will produce better port velocity and more intake inertia. For a high performance modified race car or a drag race car you would want an intake manifold runner diameter that is approximately 90% the size of the intake valve diameter on a two-valve cylinder, or approximately 110% the size of the intake valve diameter on a four-valve cylinder.
In terms of intake manifold runner length, a longer intake runner produces better torque at low RPM, while a shorter intake runner produces better power at high PRM. Generally, an intake manifold runner that is in the region of 200-300 mm long will sustain power at high RPM but little power at low RPM while an intake manifold runner that is in the region of 300-400 mm long will start building power from low RPM but will run out of power soon after peak power is reached. But note that the intake port on the cylinder head forms part of the intake runner. Thus the intake runner length is measured from the intake valve seat to the intake runner bell mouth, and not from the end of the intake manifold.
As with tuning your exhaust system, the intake manifold is best tuned on a dynometer, but it is much more difficult to make changes to the intake manifold so starting from a good base is best.
l2s_turbo
1,068
154
What i meant is the exhaust manifold to mount the turbo charger.. anyway good info for that.. Thanks.
turbololoy
Dec 11, 2011
11
503
Melaka
For exhaust manifold that help to reduce lag for turbo, i will suggest to use the Ramhorn type. Our team in Philippines are all using this manifold type, even myself for my B16a turbo charged Civic SiR.
l2s_turbo
1,068
154
Wow.. nice looking but which maker does it for 4g63t unless custom?
turbololoy
Dec 11, 2011
11
503
Melaka
For the brand, there's alot af aftermarket company that produces manifold.
But one thing is important, how thick is the metal of the exhaust manifold? The best one is to have schedule 40 material, then your exhaust manifold would not crack if you boost too much.
l2s_turbo
1,068
154
But mostly those design are different from what you recommend here.. "Ram Horn" design.. they only have it for those Honda's engine..
l2s_turbo
1,068
154
Just stick to stock. It'll never fail u...
Why is that so? Care to explain a bit more? Then what about those aftermarket headers? After install will become more worst/more lag?
Fresh from locking its crosshairs on Ferrari, the battle to take on the Prancing Horse could see Lotus design and develop the V8 mill for the 2013 Esprit on its own, according to top dog Dany Bahar.
While the Norfolk based outfit are more synonymous with their chassis tuning and handling aspect, they’re also still an engineering firm, and a...
