Top overhaul guide
Hadi17
145
10
518
Johor
I don't know about Shah Alam. My recommendation is in Kepong. One of our more popular GRA racers Mitch Chong's workshop. The fella is reliable plenty. Just don't let him poison you into turning your car into a GRA racer. :biggrin: (seriously - he's good)
GRA- Grass Racing Autosport ??
yup..
---------- Post added at 09:51 AM ---------- 6 hour anti-bump limit - Previous post was at 09:33 AM ----------
Hi guys,
Talking about engine balancing. i still dont understand the concept.
I heard engine internal can be only do balancing 3 times(i assume is only the crankshaft part only).
Let say i'm going to DIY, Which part i should sent to engineering shop?
I should send :
1. Crankpully
2. Crankshaft
3. Flywheel
4. Conrod
5. Piston ( need to send with piston ring inside also?)
6. Camshaft with it's pulley?( This part needed?)
7. Torque Converter ( let say i drive auto, this part also need to sent?:biggrin:)
8. Or gearbox itself also need to send to balance?:confused:
9. Clutch plate with it;s cover
Is there a few type of balancing? like semi balancing, high speed balancing?
Wait - you're talking about balancing right for an auto? Let me share my own experience :
1. & 2: Crankpulley - Yes but make sure you choose a final item. The original pulley will break eventually and if you swap it out then it'll be out of balance. So if you decide to go for an aftermarket pulley, make sure you buy that then send it for balancing together with your crankshaft. Since the crankshaft is out as well, hook it up with the torque convertor for balancing.
The rest no need la. Auto where got flywheel one?
Balancing is like this - if you've never seen an Evo balancing shaft, you should go find one just to play with it for 5 minutes. Try rocking this shaft and leave it to rock side to side by itself and you'll see why it's called the "Balancing" shaft. It'll keep rocking by itself for a good 5 minutes before it completely stops moving. Try doing that with any other sort of shaft and see.
So now imagine if your gb, crankshaft and pulley are all balanced perfectly and can spin on their own momentum for longer periods of times, less stress on the engine and easier revs. The difference between a perfectly balanced engine and a not balanced one is very easily seen on the revs.
for questions regarding TITAN products, who am I supposed to PM, 'cause I usually work at night, so can't call to the office 'cause its closed by the time I wake up.....
my question is, I'm now using GAB sports absorbers + original springs (cause GAB don't have sports springs, just the absorbers) for my A31 Cefiro, is there any TITAN springs that can fit in it? or can custome made the springs to fit my absorbers in TITAN? What I want is those thin springs (similar like those on the...
