I still think it reads high regardless.
you tot
i think
but who confirm???
where is de confirm??
I think it reads low
actuali i KNOW it read low cos i ran the test b4 both accel n gps same time and compare many time
what test you have done????
you dunno that the reason why gps phasing and magnitude is low or off is bcos of filtering in sofware n inherent the lower de data rate of de system like 10 vs 100hz
you oso dunno that the phasing is simple fix in sofware and oni bcome problem in veri fast race car
all these time attac car all no problem one
n can phase in sofware
de thread link before oso confirm is low hahahhahahha
There was a vice-versa phrasing there unmentioned. I think the forummers that went and read the thread can see the debate for themselves and make their conclusion.
why? cos you tot?
i tink??
n nobodi confim????
dun tink pple here is all gongong one cannot see your rubbish ok
got some pple here also quiet quiet never say anyting
oni i say cos now yr end holiday no racing seng quite free ok
Don't listen to me or laptimer.if you're doubtful about the accuracy. All information is out there, and you guys can read them and do practical tests and see for yourself.
yes do de tes! go track and do de test!! hahahahhahah
For me, i'd rather attend to other things, because I find this debate officially over.
is not over!!
is you run run oni
say soooooooooo many wrong ting
cannot proven
den you run
try yahoo den oso cannot work
den run agaaaaaiin!!!!!
The gps data quality pdf already has all information about how accurate gps is (even if it's 100hz) and why for certain readings gps better, and for some readings like lateral g an accelerometer is better.
yes! n pple have to see wat kind car is using!!
is formula car?? very fast ? very twitch?
or heavy time attack car 20 secon slower??
hhahahhahhahhah
Also, accelerometers been used in track racing for a long time, and there's even general guidelines to compensate for body roll depending on type of car.
long time b4 de gps technology get so good as now hahahha
HELO! shiroshiro! de road cambre and de roll how to compensate accuratly for both without oder sensor to tell you sprung mass orientation????
how to compensate for de slip angle at de same time as de roll and de camber???
hahhaha i give you answe ok!!
ANSWER IS, YOU CANNOT!! IS BECOMES ESTIMATION IF YOU DUN HAVE DE ODER SENSOR!!!!
Well, rather than explaining more about slip angle, I invite forummers to read about it. It determines cornering forces, so it's good to know so you can see what kind of g's you can expect when your car turns, but it's not an element to calculate/measure lateral g per sep
well it is can see dat shiro OSO DUNNNO about slip angle
i invite forummmers to see dis
he say is not element to measure lateral g
BUT IT IS!!! hahhahhahah
is why he cannot answer the question i ask him hahahhahah
he keep ranning
keep say later later
oni can yahoo n hoping to fine answer
but he wun fine cos dis one is come from ah seng head!! not yahoo!!!
n is wat shiro cannot answer!!
---------- Post added at 06:49 PM ---------- 6 hour anti-bump limit - Previous post was at 05:07 PM ----------
ok lah make simple question for de expert shirotenshi
see if he can answer hahahhaha
ok i open de dictionary and english textbook try to saying clearly de question
hahahah no actuali i ask my cousin to write for me
dis one not on yahoo ok!!!!
A car is negotiating a turn. The car has only a 3 axis accelerometer installed.
At time = 2.0 sec, right in the middle of the turn, the 3 axis accelerometer shows the following:
longitudinal acceleration is +0.12 G
lateral acceleration is +0.83 G
vertical acceleration is -0.04 G
Chassis slip angle, sprung mass roll, unsprung mass roll, road gradient and camber, are all unknown due to lack of other sensors.
What is the true lateral acceleration of the car at time = 2.0 sec ?
