Mine is standard 510cc injectors and the pressure is somewhere near std (I was told la. Not too sure. need to check with mech).zaki said:can i know you fuel regulator pressure? how big are your injectors?
GroundZro said:Mine is standard 510cc injectors and the pressure is somewhere near std (I was told la. Not too sure. need to check with mech).
I have a fren who is running a 3s engine with a big ass turbo (bigger than T67 but smaller than T88). Something like a T78 turbine. Boost is set to 1.4bar. Also using Evo 510cc injectors. He said for short drags, they are enough. He doesnt drive his car tht often. Mayb press the car once in 2 weeks only.
Mayb jo1 is right. I was told to change my injectors if I wan to get more power out of the car. Of cos this will be done via tuning.
Miton, damn!!! U really went the 2.4l way? I was only joking about it in the other thread.
Crazy meh 30+psi...you think what? tyre pressure ah?dolly said:miton, you must be talking about your 30+psi setup hehehe
my 14psi setup is running with a few degrees (can't remember how many) of ignition advance
Yeap. He needs more. He has 2 extra injectors hooked up but seldom use them.zaki said:there's something not right, i don't know, maybe i need to learn more. 4 x 510cc can support close to 400hp. those setup might need more.
great!! his car must be flying.GroundZro said:Yeap. He needs more. He has 2 extra injectors hooked up but seldom use them.
Miton,
Give free, i wan.
