not possible to go back to pure boxer sound just change extractor,uppipe,downpipe,oil pan and single scroll turbo and you get pure high end boxer sound,but lose more 500rpm turbo lag lol....just a noobie question.
Is it possible to make a Ver.8 to have the old school sound of ver.5?
u know, the old skool turbo boxer sound that makes a boxer so distinct from others?
Just like the Harley...
Cos the newer version just sounded a bit not so boxer to me....
just a noobie question on a scooby doo...hope someone can pin point...thanks
Sti improved this turbo lag weakeness for V8 onwards by using equal length header and twin scrool turbo. SO don't go backjust a noobie question.
but the sound like double I-vtec,no more boxer soundSti improved this turbo lag weakeness for V8 onwards by using equal length header and twin scrool turbo. SO don't go back
thanksSti improved this turbo lag weakeness for V8 onwards by using equal length header and twin scrool turbo. SO don't go back
sorry this not my car is our member car,Ronnie how come your original engine compression ratio is 8.00:1 did you put thicker gasket?
By the way your engine oem the 2.06 bar is very very dangerous man.
Tq for the info ronnie
papa snail got two set off v-pro if u want call him,dono your engine built need see first piston and gasket.Thanks man can papa snail can tune f con vpro(i plan to install next time)?
What he do to the engine(share abit bro) common the oem ej20 engine compression is 8:5:1, did he put lower compression piston or thicker gasket?
not 2.06 bar now running 1.6 bar only,dyno machine boost hose got problem.Ronnie how come your original engine compression ratio is 8.00:1 did you put thicker gasket?
PISTON is mahle 93mm piston manley h beam rod and cosworth bearing head gasket oem. How many boost can it be. My engine builder told me max 1.7barpapa snail got two set off v-pro if u want call him,dono your engine built need see first piston and gasket.
---------- Post added at 01:25 PM ---------- Previous post was at 01:20 PM ----------
normally vfxx turbo only can support maximum 1.5-1.6bar (in dyno not using defi or xxx),if your engine forged already sure can support 2bar ++,but your turbo lel...???PISTON is mahle 93mm piston manley h beam rod and cosworth bearing head gasket oem. How many boost can it be. My engine builder told me max 1.7bar
Similar threads | Forum | |
subaru specialist... | Scooby Owners Club Forums |
Similar Threads | ||
