rebuilt gearbox hard shifting problem
upontheriversky
275
82
hi,
i have just had my kelisa 5 speed manual gearbox rebuilt. oil seals replaced and total cleanup is done on the gears and housing.
im not sure if its a problem but i find it rather hard, like a bit tight to shift especially the lower 3 gears, shifting from 3 to 4, 4 to 5 and back seems butter smooth. once a while, shifting to reverse caused chatter sound. could it be the new gear oil? i heard hard shifting is normal for new gear oil, but could be a myth.
and i have just serviced the clutch system with upgraded heavy duty clutch. can higher rating clutch induce hard shifting?
opinion is appreciated :D
DanzEterna
15,911
3,371
www.primeperdanaclub.com
maybe this could be solved by adjusting the gear lever abit..
happened to me before canot shift into 5th gear after rebuild gbox, send bck to my fren
he solved within a couple of minutes...he said adjusted gear lever something like that.
upontheriversky
275
82
adjusted the clutch cable making it engaged at higher foot position, so when pedal is pressed completely, clutch is fully disengaged. solved hard shifting and kreekk during fast reverse shift problem
thanks!
avielboys
82
20
JB, Johor
powerpackengineering.blogspot.com
if the gear cable installed wrongly can also cause this problem ... i kena on a perdana v6 manual b4 ...
but this problem only for gear 1 & 2 ...
as for gear 2 & 3, if you using china made short shifter, you might encounter hard shifting ...
upontheriversky
275
82
how it can be wrongly installed? how do we check? might want to check for it as well
The Marketplace Top Posts
just out of curiousity, whats the highest HP and torque on the GSR 1.8 ( 4G93-T ) that uve seen...
discuss !!! :regular_smile:
