RB26DETT Oil Pumps advice needed.
angelz88
33
34
Kota Kinabalu
Hey guys:wavey:,
I'm driving a R34 and as of last month my oil press is reading slightly below the norm. It's reading at less than 0.8-1 Bar on normal driving and 1-less than 2 Bar on cold start. Somehow it's showing early sign off oil pump failure.
The purpose of this thread is I want to get opinion from the sifu's and other RB's user regarding their oil pump upgrade. Cz im contemplating between should I just settle with N1 or higher ends like HKS or JUN or REIMAX that'll cost a bomb. Hope to hear it from you guys soon.
angelz88
33
34
Kota Kinabalu
Yeah, I looked tomei up too but it requires more than just their oversized oil pump but also oil restrictor? and oversized oil pan? and all the other oilling upgrade parts. can anyone confirm this?
gobiz2
407
125
543
If not mistaken, the restrictor will come together with the oil pump when you buy. Extended oil sump is always recommended but I think you can also adjust the flowrate of the pump if want to maintain the standard oil capacity.
angelz88
33
34
Kota Kinabalu
Gobiz2: bro, Tomei oil sump itself priced more than the pump :banghead: haha. you are using tomei's one i suppose :rofl:
Shark79: I'm running on 500Whp bro. and im just worried of the reading that my oil press gauge is showing. It could be the sender unit to the meter cluster but i dont want to take any chances. haha
V-Spec
1,861
170
5,163
Hi. You can also consider NITTO Oil Pump. They are equally raved upon by Skyline users especially in Australia and the UK. I have ready stock of NITTO Oil Pump and Nissan N1 Oil Pump should you require one.
Thank you.
angelz88
33
34
Kota Kinabalu
Shark79 : What other supporting mod would you advice bro?
V-Spec: Do pm me the price for both oil pumps bro. thanks
gobiz2
407
125
543
Can get much cheaper extended sumps with other brands or custom-made.
Honestly I wish I had used Tomei, otherwise my engine wouldnt have kong...and subsequently sold my car 2 yrs ago haha
So many rb engines have perished due to oiling issues and then the owners sold the cars hehe
feezdya
1,814
223
Pee Jay
www.takaful-ikhlas.com.my
Hi Angle,
When you said you are running at 500whp, for sure your oil pump is not standard anymore. N1 oil pump reading similar as per your reading right now unless if you done some modification to add washer in the oil pump, the flow much more better. Tomei is quite expensive but you also may consider Nitto (JDM Autolink got stock) since the pump is new technology than others.
BTW who done you engine? yourself or previous owner?
Gobiz2- I noticed last time you ade jual BNR34 steering pump..still have it? i need it bro.. TQ
angelz88
33
34
Kota Kinabalu
Hey bro, thank you for your reply.
Im not sure if it has been changed cz the previous owner did not mention anything about it and the reading seems kinda low (from what i asked around). But you could be right.
The previous owner was the one who sent it to be tuned but i myself met the tuner and asked about the car and he cant recall much. lol
The Marketplace Top Posts
Having question, which alot people said that open pod was`t suitable on automatic transmission.
I have few numbers of friends installed open pod on their automatic myvi, vios, persona, accord, civic and 350z also having good result on performance increase.
Another weird answer from a friend with 350z roadster is better fuel consume after installing a long ram open pod + CAI with heat shield cover.
I`m currently going to do a short ram intake with heat shield cover for my 1.5l automatic...
