Originally posted by .S K A G E E.@Dec 31 2004, 09:58
Yo..Ricky ma'nigger
Contrary to the popular belief (heeheehee) the Rb26 engine isn't as weak as what it is made out to be. Sure, we hear cases of spun bearings and stuff but only due to parts failure or due to pushing the engine further than what it was designed for. I'm sure people at Nissan would have address to the problems immediately if there was a inherent design fault in the engine. With only a few minor alteration in the RB26 across three generations of GTRs , i would reckon, is a testimony of its sound design .
Yes, you would need upgrades if you're pushing high horses but for the moment, I would only recommend the baffle plate for the oil sump if you're planning to drift with it. Get a proper oil pressure meter with an audible warning beeper to warn you incase low oil pressure and a water temp meter too.Just remember to keep your boost and rev sensible. Use the best engine oil you can find (remember: good doesn't have to be expensive LOLOLOL) and change it regularly and you'll be fine .................................................................i hope ..LOLOLOLOLOL
