Proton Wira/Persona Fuse Box Diagram?
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
have you tried removing the fuel hose at the fuel pump and crank the engine when its cold?
another long shot item is the fuel filler cap.try borrow from one from similar model.
parakey
1,367
226
663
I had the fuel pump replaced and while the car was up on the jack, I manually checked the steel lines leading to the front making sure there are no crimps or irregular bends. Wasn't expecting anymore fuel issues
Interesting, I never thought of the fuel filler cap. It's a long shot but interesting idea of how cooling temperatures may produce a slight vacuum air pressure preventing fuel from being pumped out.
Will definitely look into this. Thanks
On my Chery SUV I am getting a reverse effect. Normal crank start every time, but if I open the fuel cap to refuel then close back I have to crank longer to start, or at least 3 times. Once started, it becomes normal again unless I open the fuel cap.....lol
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
I wonder if the breather assembly will cause any issues
have u check if your car sending enough fuel pressure for priming?
do you heard any fuel pump sound during first key turned-on?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Even if fuel pump, first already changed and second why only morning:smokin:......lol
Not suspecting the fuelpump... But more towards fuelpump controller...
parakey
1,367
226
663
Update - The past few mornings, I had difficulty starting the car. So I opened the fuel filler cap. I read if there's a vacuum, there will be a whoosh sound when the cap is opened. Didn't hear any such sound. I just open and immediately closely back. Strangely, the car was able to start after that. Each time it won't start, I just release/normalise the pressure in the tank and it will start.
Thanks to all who helped. Specially gunnerzz :party:
Now I have to wait till I finish that full tank of petrol before I ask the workshop to lower the tank :biggrin:
Still want to find out why it's not breathing properly
So the reverse of my Chery SUV effect. Maybe you need to use a loose fuel cap......lol:rofl:
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
The fuel filler cap has a function but i forgot what it is.
my brother and i was doing trial and error to find fault in his fuel system not to long ago and he did teach me but i forgot already.
Anyway,glad to hear it solve the problem.
might as well change the fuel filler cap.
if its raining then difficult for u to open the fuel cap rite..hahahha.
The Marketplace Top Posts
Unfortunately for me, I somehow corrupted some of my photos and need to retake the brake bleeding process so that'll be done in part #3 of the 'how to improve braking performance' series.
But for now I'd like to discuss this particular modification that I had done - Steel Braided Hoses.
The original OEM brake hose is made of a special rubber compound that's able to withstand the 1000psi (probably less...
