Proton Waja Cps ABS Problem
Dec 3, 2009
Johor
hi,
I hv problem with my waja cps abs the abs light keep on a few days n i hv to switch off again
then the light go off, sometime it will not go off n i hv to keep trying a few time. After sending
back to eon service center the mechanic checked n confirm is the abs modules problem they hv
issue a claim part form to me. But i hv been 1 1/2 half month now the part still not available, i hv
waste a few month including a few time of checking at the service center. Cause my car now was
nearly 2 year. Anyone know where i can log a complain to eon cause abs is for safety.
I know without ABS the break is still working as normal.
tks
simon
292
i think you might as well get it done at outside workshop if its not going to cost much...if wat you say is correct... i dont understand the rationale behind waiting 1 1/2 mth for a part for a car made in malaysia....does that part comes embedded with a diamond whereby they need to source the diamond from afrika and or some part of the world and so its delayed ???
simon
292
oh finally proton got the parts huh......i feel they shd have it standby if they want to provide a good service for their customers....anyway good for you....thks bro....
srh_85m
Apr 11, 2013
11
That is because there is dirt on the wheel sensor.... does anyone know how to fix braking power.... whn hit brake its does not capturing the car still moving n need to pump
ColdPlay
288
112
Bleeding is the answer. You need to get rid of the bubbles along the lines.
Else, check your hose it might be flexing too much thus cause unresponsive braking.
srh_85m
Apr 11, 2013
11
Bro any shops you can recommend for me to do these, i am visiting quite number of workshop and they lazy dont do it.... i am from KL
---------- Post added at 10:45 AM ---------- 6 hour anti-bump limit - Previous post was at 10:45 AM ----------
ColdPlay
288
112
Maybe they don't want to get their premises dirty. As bleeding on 4 side need about 2 liter of brake fluid.
Try the workshop behind Jusco Taman Maluri Cheras. Else, foreman 'bawah pokok' will be more than happy do it for you.
Was at Tokyo Auto Salon 2011 yest and guess what I saw..
Satria Neo! 2 to be exact. Here are the pics..
Neo R3 Concept
