depends really on wht u use it for , u need scramble ? u want to tune it using gear or speed , u want to have extra bling ? u want more accuracy ?
i tell u the pro's of everything first
greddy simplicity cos only two settings and very very easy to tune , can buy quick switch
hks uses stepper motor, very accurate and closed loop operation is electronic elimates vacuum hose to ur dashboard , no quick switch but can press a button to go scramble
blitz same as greddy bt has 4 boost settings + 1 scramble , haha dnt have switch , only button on unit
apexi can tune by gear , by speed , can monitor rpm , speed etc together in avcr and accurate cos of using boost pressure sensor like hks, doesnt need hose till dashboard, can DIY own normal switch to make scramble boost, its just wiring
cons
greddy has only boost settings , need to pull a boost hose to ur control unit
hks much more expensive thts it
blitz need to putar putar knob to change setting 1 to setting 2 or etc, its not easy while driving , need to pull vacuum hose to ur controller
apexi , hard to tune , uses stepper motor too , complicating
why i chose profec b spec II ?
first of all , i only run two settings low and high , why do i need scramble when i can just run high boost , i can buy the quick switch n switch between hi and lo , on drag race i just low boost when lower gears n switch to hi boost at higher gear , wht else to i need :) , extras not needed for me , only iritating thing is to put a tee from my boost meter n feed the controller at dashboard, same goes with BLITZ ,
conclusion, got cash ? go get EVC , u dont have RSM also to monitor other things then get a AVCR to get all in one monitoring , u know wht u want n just adjust boost , get Greddy , u dnt mind pusing pusing knob and knowing wht boost setting u r in , 1,2,3,4 then go for Blitz , heehehheehehee, sorry blitz users , i just dint like the Blitz DSBC that i used last time :P
