Perdana Oil Temp Guage for AT Gearbox
edwin_lcw
1,242
Setapak
Hey danz i see in google they say cucuk at the ATF oil pan and if cucuk on the return line the sensor adaptor usually they sell outside is very big in diameter for the ATF hose
haha logical enough...cos that was my theory only cucuk at the oil return pipe...
if want proper then can get the adaptor fit at piping...or even better if custom adaptor at the oil cooler
Actually which is best place, as different place will show different results....:hmmmm:
Actually which is best place, as different place will should different results....:hmmmm:
depends on what u want to know...
pre-cooled temp (install at oil cooler inlet)
or
post-cooled temp (install at oil cooler outlet)
or
just current oil temp in the oil pan..... (install at the oil pan)
if me personally prefer at post-cooled temp....so if the reading shoot high even after passing oil cooler...that means the gotta slow down to avoid transmission overheating...
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
That temp meter is about RM26.50. Cheap and nicer looking than Defi gauges imo. ahhaha
What i'm worried about is the way he held the sensor, silicone will slide out after sometime in my experience.
And mine wasn't even 100 Celsius.
And I want to know the current temperature of the transmission, where do u guys thing I should put in?
Can try those epoxy glue?
should use epoxy glue in the first place
<img class="alignnone size-full wp-image-31443" src="http://www.zerotohundred.com/wp-content/uploads/2012/06/bugatti_gumball.jpg" alt="" width="600" height="400" />
Have you ever been to a concert or maybe a meet-and-greet session where there will be those fanatic-type fans which will go screaming their throats out upon seeing or even having a glance of their idolized star? Usually this applies to the die-hard fans, those that really have a deep passion and knowledge about the stars, and...
