Perdana Oil Temp Guage for AT Gearbox
edwin_lcw
1,242
Setapak
Hey danz i see in google they say cucuk at the ATF oil pan and if cucuk on the return line the sensor adaptor usually they sell outside is very big in diameter for the ATF hose
haha logical enough...cos that was my theory only cucuk at the oil return pipe...
if want proper then can get the adaptor fit at piping...or even better if custom adaptor at the oil cooler
Actually which is best place, as different place will show different results....:hmmmm:
Actually which is best place, as different place will should different results....:hmmmm:
depends on what u want to know...
pre-cooled temp (install at oil cooler inlet)
or
post-cooled temp (install at oil cooler outlet)
or
just current oil temp in the oil pan..... (install at the oil pan)
if me personally prefer at post-cooled temp....so if the reading shoot high even after passing oil cooler...that means the gotta slow down to avoid transmission overheating...
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
That temp meter is about RM26.50. Cheap and nicer looking than Defi gauges imo. ahhaha
What i'm worried about is the way he held the sensor, silicone will slide out after sometime in my experience.
And mine wasn't even 100 Celsius.
And I want to know the current temperature of the transmission, where do u guys thing I should put in?
Can try those epoxy glue?
should use epoxy glue in the first place
To all my friends in here..
I like to let's u all know that custom BR racing clutch was very disapointed:bawling:. I had used this kind of clutch for my H22A vtec turbo. 1st time i send it to BR to rebuild my racing clutch, it was vry
slipped. Langsung x bleh nak boost. Then i resend it for a second time to BR and he said my clutch cover need to upgred, ok. i let him to upgred. When fix it to my car, u know what happend? my padle clutch keras gila babi..xbleh tekan..last time used...
