Open Pod Air Filter
pot
5
Hi guys...
I'm currently using 4G91 with stock air filter..thinking of changing/upgrading to
open pod air filter....what is the advantage/disadvantage of using it...and the cost
for the complete open pod system..
Thanks....
SkYwAlKeR
10,139
300
ePoh ~ malacca
advantage
- feels smoother revs at high rpm
- achieve higher horsepower at max rpm
disadvantage
- sluggish at low speed
- low end torque might lost a little
price
- varies according to different brand
pot
5
Bro Skywalker...
Thanks for the info...
evoX2
1,167
KCH
when u do open pod make sure u get cool intake... it make diff alot...
add heat shield too. If not u better keep it stock, with Malaysia hot temperature you will lost more than you gain.
pot
5
jeffayn & evoX2...thanks for the info...
if I still plan to use the open pod...so I need to use the CAI just like Skywalker sell..then I've to put the heat shield..
what if I just stick to the stock air filter and buy the K&N drop in instead of open pod...
the K&N drop in good or not ??
thanks again..
jeffayn
621
62
3,028
Klang
if you plan turbo charge, you must mod,
or else, drop in more than enuff lio lor....:rofl:
SkYwAlKeR
10,139
300
ePoh ~ malacca
thanks again..
drop in is good for city drive... but spirited drive is abit less enthusiastic compare to open port... it doesnt give u the open port roar sound.... high rpm feels a little bit restricted compare to open port.....
both filter element is the same.... what makes the difference is ur oem airbox... by using open port air filter, u dont need ur airbox... air flowing to ur filter will not be restricted....
as in drop in filter, u still use ur oem airbox... air flow is restricted by the size and shape of ur airbox air inlet....
there are more creative methods modifying ur airbox... drilling extra holes to compensate the need of high flow at high rpm... yet u still enjoy the cheaper drop-in air filter and oem cai intake that comes with ur car....
dennisdreams
333
21
you risk frying your valve/piston for air/fuel ratio will definitely went extreme lean on high rev. hoho~ experience it first hand on my BT T_T...
SkYwAlKeR
10,139
300
ePoh ~ malacca
drill holes on airbox before all ur sensors... even before ur air filter.... not drill holes after ur maf sensor or after ur throttle body....
imperialrealcs
70
but the engine will get real dirty quick? indirectly harming the engine since it was not filtered?
what about auto with open pod?
loose_end
3,649
197
Malaysia
"there are more creative methods modifying ur airbox... drilling extra holes to compensate the need of high flow at high rpm... yet u still enjoy the cheaper drop-in air filter and oem cai intake that comes with ur car....[/QUOTE]"
http://www.psmdiesel.com/downloads/03-04 w fog lights Installation Instructions.pdf << Is this the one to modify the air box
Hi! guys!!! :biggrin:
just want to ask bout' what is a difference between LSD Gearbox & Full Lock Gearbox coz' I'm lookin' an Evo3 g/b, I goes to some chop shop n ask for g/b, I said I want a it wit LSD but the guys said it is a non LSD g/b but it can be Lock to 2 wheel, I'm quite confused here :hmmmm: , is it mean that from 4wd lock to 2wd or from non LSD to LSD, some of the thread in the internet (not only ZTH) also wrote the same "Evo3 g/b for sale, non LSD but can Lock to 2wd" I know...
