Previous mechanic overtwisted that damn thing and now I couldn't open it up to replace the filter. Anyhow I can fix oil filter relocation kit to it? That damn plastic cost about RM400+!! Ouch...
reintel,
wah... u need to open it la bro...
How to install relocation kit, as u need the attached at the same source.
Nissan frontier got half cut no worries...
Finally decided to upgrade the frontier with Navara parts. I just bought the Navara oil filter plate to replace the ori in order to use Navara steel oil filter. Next question. Is it a plug and play job? anything i should beware off?
Hi, i found a pair of Subaru impreza stock semi bucket seats, thinking of fitting them in my kenari. After measuring, the impreza seat original bracket is more less same as kenari bracket. just minor difference. Question is, must i use weiding to even out the difference, or i could just use thick metal plates cut fit to size and use nuts and bolts instead of welding? Thx!! i thinking of Diy install. if using nuts and bolts just fine i could just proceed install myself.
