Need help...silver top cannot start
zmays
271
26
any sifoo please help me. happened this evening. when i started my car, after idling for 15 minutes, engine sudenly dies. then try to start again but failed. can crank engine but there is no sign of ignition/combustion happens. never encounter this problem before....
there is a smell of petrol when crancking the engine. but no leaking. can u help me how to know if ignition coil or fuel pump fail??
Adeen
2,726
6
kl
when idling for the 15 minutes.....was the timing and everything ok...??
once my car didn't want to start.....and it was because of my burnt ecu....
zmays
271
26
ehh sorry..wrong info.not 15 minutes. but 15 seconds. i started the car while raining. then suddenly it dies..the timing was ok..no jerk or unstable timing...it dies off suddenly...
if the ecu is burnt, how to recognize it ehh?
TRD16v
1,802
5,138
Tokyo, Japan.
If got burnt ECU, u can take out the ECU and then see if its hot or open internal to check on the circuit board.
Maybe spark plug wet, too much fuelling so need to take out spark plug and check.
If got petrol smell where does it come from? If during rain, humidity also different as wind blows mebbe also make it hard to detect.
Regards,
Mike
scomatic
2,147
25
1,648
Kota Bharu, Kel
I worry is your distributor or spark plug enter water. Try u start when after rain.... start until it servine back by don't press gas.
zmays
271
26
my friend asked me to check fuel pump and coil. but the problem is i dont know where is the fuel pump located. becoz i'm using external fuel pump. can see fuel line, but daont noe where is the pump..
zmays
271
26
my car now at workshop at kanpung. now they are checking for my fuel pump. hopefully the prob is not the ecu. if it is ecu, how much the price ehh?
Adeen
2,726
6
kl
Levin 818 got the ecu....rm300 if i'm not mistaken....and he'll offer u rebate rm50 for ur faulty ecu..
yolk
1,144
PJ
nowdays many ecu problem ??
cuscostrutbrace
987
62
3,028
For an engine to start,it needs fuel,air and correct timing.Check all those first.If no fuel check fuel pump,check power supply and ground to fuel pump.If no spark,check if coil got power or not,check distributor,last thing to check is the ecu,check the ecu power supply and ground.Dont forget to check all fuses as well.Good luck
levin818
1,260
321
3,183
Shah Alam
faulty ECU
If your engine went stall (straight down) after warm up, but can be start again after cool it down for say 30 mins, most likely your ECU is mulfunction.
When i had a faulty ECU 3 yrs ago, my engine stall after run 5km from home, crank up the engine and it made 2km b4 went stall again. The distance getting shorter and shorter after that, like 1km.. 500m... 10m... then refue to start up totally. The frastruating thing is, it doesn't have any error codes at all and you do not know whats went wrong.
Most of the SVT ECU already reach its life span and the components inside starts to fail. Thats why many SVT owner encounter ECU problem now. Lately i aslo seeing BT ECU givig problems...
levin818
1,260
321
3,183
Shah Alam
I am not sure but it could be some design's calculation wasn't optimised.
One thing for sure, don't run your engine with a clogging ISCV. It will push your ECU to run at high current mode and this will further shorthen its life span.
i have a honda civic so4 with d16a non vtec inside..auto transmission..
-recently my car is having jerking problem at 3-4rpm..firstly i suspected it might be missfire problem.so i replaced new plug cable,spark plug,distributor cap..but the problem remains,i even swap another distributor as well as ecu,but it still remains.
-later i tried to use ron97 fuel and the jerking problem gone.but after 3days it started to happens again.fuel consumption also bad..full tank of ron97 only able to get...
